Upgrading damper/air spring on Rockshox Yari RC
coarselanguagw
I have a 160mm Rockshox Yari RC fork, from a 2019 Ebike. It’s a Ebike optimised fork and has the small emts sticker on the crown.
I wanted to upgrade the damper and possibly the debonair air spring as well.
When I checked https://trailhead.rockshox.com/ and clicked on “upgrade kits” nothing appears. The fork info from trailhead shows:
364138
Also the damper upgrade kit manual I found online here doesn’t seem to list this fork as compatible.
Can I upgrade the damper or internals on this fork or am I out of luck?
If I were to sell this fork, it's not in great condition what might it be worth?
Nambra
Looks like it is upgradeable. The serial number says it’s a 2019 fork.
Start reading here: https://www.sram.com/en/service/models/fs-yari-rc-b2
Theres a bunch of documents there for you to read. A quick flick through the Charger Damper upgrade document indicates that the Lyrik damper kit should work.
edit: just re-read OP’s post with linked document. This is the part number referenced in that document as the damper upgrade for the Yari RC B2, but as @DMan suggests, give Cyclinic a call to confirm.
https://cyclinic.com.au/products/rockshox-lyrik-yari-charger2-1-rct3-damper-upgrade-kit-boost
DMan
Give Cyclinic in Brisbane a ring. They'll be able to tell you and if possible, do the job.
