yuley95
Rides a great parmie
in the interests of transparency, I may have put on 200gm over covidOh to only be 72kg! Imaging only hearing that noise if you case stuff, instead of just general riding through rockgardens. lol
Sounds more like a rim tape issue to me.Has anyone here running the Rimpact inserts had issues with air seeping from between the bead and the rim? I've set my rear wheel up with 2 different tyres and both times there are a few points where it will continuously release tiny, tiny bubbles from between the tyre and the rim. Enough to lose about 20 PSI in 24 hours.
I actually swapped my front tyre to the rear, as this doesn't leak on the exact same rim on the front, however now with the insert on the rear wheel it seems to having the same issue the rear tyre was.
I was thinking that potentially as the insert is up tight against the bead, it may be preventing any of the chunky/thicker sealant from being able to get in there and clog up the tiny gap?
Any ideas/tips?
I run Rimpact and haven't had this issue. I've run two different tyres (Maxxis and Goodyear) and not had any issue. Is the sealant off? Do you hold the wheel on its side and tip it back and forth to coat the bead once inflated?? Not sure what else could be going onHas anyone here running the Rimpact inserts had issues with air seeping from between the bead and the rim? I've set my rear wheel up with 2 different tyres and both times there are a few points where it will continuously release tiny, tiny bubbles from between the tyre and the rim. Enough to lose about 20 PSI in 24 hours.
Any ideas/tips?
Could be that there's a spot where the tape was lifted/crumpled by the tyre bead the first time you fit the Rimpact (you know how they tell you to "pull" the bead in under the insert) or similar... I just had to put some new tape on my dad's road wheels this morning because he'd managed to lift/slide/misplace the tape in one spot (I assume with tyre lever while fighting a tight bead) that meant that they'd seal up okay and seem fine in the hand but be flat by the morning - was just enough to prevent proper sealing.I've used the blue Bear stuff @moorey and a couple others really rate. I do have a different tape in the front though so maybe it does have something to do with it.
Brand new bottle. I shook/banged/spun/harassed the crap out of the wheel after inflatingI run Rimpact and haven't had this issue. I've run two different tyres (Maxxis and Goodyear) and not had any issue. Is the sealant off? Do you hold the wheel on its side and tip it back and forth to coat the bead once inflated?? Not sure what else could be going on
That could potentially be it, it's not the easiest thing to fit without a little force. I might have to pull it all apart tomorrow and double down on the tape.Could be that there's a spot where the tape was lifted/crumpled by the tyre bead the first time you fit the Rimpact (you know how they tell you to "pull" the bead in under the insert) or similar... I just had to put some new tape on my dad's road wheels this morning because he'd managed to lift/slide/misplace the tape in one spot (I assume with tyre lever while fighting a tight bead) that meant that they'd seal up okay and seem fine in the hand but be flat by the morning - was just enough to prevent proper sealing.
I'd try replenishing the rim tape (or even just banging another layer on if it looks okay visually) - there's nothing about Rimpact that should be preventing the tyre bead from seating/sealing in the rim.
If the tape doesn't fix it, then... what's the rim? Sounds like it's rear wheel specific and tyre-agnostic, so maybe there's a little crack in the rim bed/bead or something? Al or carbon?
When I needed to remove tyres with cushcores I found that a Stanley knife made the job easy.What's the secret?
