Item: Trickstuff Maxima Brakeset
Item Condition: Brand New in Box
Reason for selling: Change of direction
Price and price conditions: $2300 +shipping
Extra Info: Currently in transit from Germany. Have waited 18 months for these. AFAIK they still aren't taking new orders. 900mm and 1700mm Stainless Steel braided Goodridge lines
With the Trickstuff Maxima disc brake, any talk about the strongest bike brake should be over. It is the most powerful brake Trickstuff has ever built, making it the most powerful bicycle brake in the world. Building a strong brake was actually quite easy, but what wasn't was to build a brake that has the usual superior dosing of all Trickstuff brakes despite it's immense power. Because without control, power is worth nothing.
Starting with the Trickstuff Direttissima, the Maxima features higher mechanical and hydraulic ratios, increased heat capacity, larger pad surface, longer finger levers with more progressive ratios, and more mass on the caliper for increased stiffness.
Features:
outstanding look and feel
use of CNC machined aircraft grade aluminium 7075 T6
offers a clearly defined pressure point
9 mm primary piston
16 mm and 17 mm secondary piston
use of high quality mineral oil (organic bionol)
tool-free lever width adjustment
optionally different shift lever interfaces for SRAM and Shimano (I-Spec 1, 2 and EVO) are available
Pictures:
Features:
9 mm primary piston
Pictures:
