Tire Pressure
toodles
Front: Intense 2.7 (not rich - came on bike) 12-14 psi
Rear: Maxxis Mobster 2.7, 22-25psi
Dice rims, XC tube front , DH tube rear
Ride_Guy
DH bike
Front: Tioga white tiger 2.5 i think the best conering tyre ever!
Rear: Maxxis minion 2.35 ramped knobs rolls fast digs in well for braking
Jump bike
Front: Duro wildlife 3.0"
Rear: Maxxis high roller 24" x 2.70" super tacky
danncam
Big grave dig as this thread is what turned up when I put "tire pressure" into the search bar.
Had a nice solo ride at Silvan again, and the odd bit of trail was slightly greasy clay. I believe come wet winter weather much of Silvan kinda ends up wet greasy clay.
Any thoughts, opinions or experience out there about whether tire pressures should go up, down or stay the same to maximize traction on clay-ish trails?
Tubbsy
Packin' a small bird
You may have misspelled 'tyre' when searching, here is a more up to date thread:
Americano spelling of *tire.
You'll want to find tyres that will shed the clay mud away in the wet. I usually lower the tyre pressure a few psi to get traction over rocks and logs because the clay can act like soap and make you slide all over the place.
danncam
Thanks, clearly I was too lazy to try both spellings.
