Thinking of giving a gravel bike a crack
Modern MTB geo is horrific for aerodynamics, there is a very serious reason the XC pits are ruled by -17 stems.
There’s lots of free speed being passed up with this hood mentality, I’d suggest at least trying the drops occasionally and seeing how it goes
I have tried multiple times, but for me to be on the drops and be able to get fingers on the levers I have to get into a pretty uncomfortable position. I'm sure a professional bike fitting would go some ways to fixing the problem, but I don't ride that bike with serious intent. It's really for commuting and fitness for actual MTBing.
You may get there by raising your bars a little but it could also be a long stem, deep drop bars etc.
If you are spending as much, if not more, time on the commuter you may as well use it to its potential.
Here’s some pics of my Search’s bar set up, was playing with bar tape setup then ended up using the Ritchey drop bar grips that I got a while back, I have trimmed them down slightly. Now I just need to dial in what stem length I need, currently running a 70mm but I think I will go up to an 80mm.
I've got to try some different bar types, mine are very stock standard and those look pretty interesting.
There’s plenty of flared, low drop bars around now. I have had Salsa Cowchippers previously on a bike and loved them.
Currently using Ritchey Butano for a more traditional approach but there’s Beacon, Venturemax and Corralito models which all fit the bill and are cheap in alloy.
I've got Ritchey WCS Venturemax and
Spank Flare 25 Vibrocore Drop Bar on different bikes and both are very good.
The Spank definitely filter out more road chatter.
Random question but what's stopping more people from picking up a 10-15 year old XC 29er and fitting drop bars, rather than getting a dedicated gravel bike?
I get that retrofitting a drop bar cockpit set up with new brakes and shifters isn't exactly cheap, but I've seen stacks of older well specified lightweight XC bikes being basically given away recently. Could be an option?
Gearing is biggest issue I reckon. No clearance for gravel chainrings.
Having to source a rigid fork is the other.
Having said that, I went a 2013 GT when building a bike for Seven. With 2x front and 9-42 11sp rear I had the range of gears I needed. Honestly still think flat bars and suspension up front is better for gravel.
Oh yeah, did not think of that.
Is.... a 2x drivetrain the answer?
2x drivetrain is great for gravel gives you good top end and bailout gears without a huge cassette.
My current gravel bike is a 2009 Steel Jamis Dragon one 29er running 2x10 with 42/27 and an 11-36 cassette with cable disc brakes. There's only the odd occasion when I wish I had a bigger chainring to push a bit harder on a downhill section. Geometry is close to gravel bikes of today and I enjoy riding it even if it's a 3-4 kgs heavier than a modern carbon bike.
Sent from my moto g75 5G using Tapatalk
It’s certainly quite popular with the more adventurous gravel riders.
There’s a large divide in what people call gravel too, most people want to have a slightly more capable road bike that they use at road speeds and require the gearing to match.
Nothing. I run the Twinzer in gravel mode (MTB XC 62 mm tyre up front, 50 mm gravel tyre out back) these days using a 2x setup (there's no way in Hell I'm doing a typical dirt road traverse on a 1x around here). I wouldn't run drop bars on it (they will work with the geo) though I would consider a Jones Bar style arrangement if I was super keen.
Jones Bar! That takes me back to the very first days when I discovered this forum, the 29er thread and some seriously sweet custom Blacksheep builds a few people on here had, all rocking Jones Bars. Man, what a time, a great *continues boring nostalgic monotone for a further several minutes, eventually devolving into rambling about single speeds and the optimal tune for an RP23 they got these chewy pretzels 5 dollars? get outta here*
Jones risers bars are the best, so comfy especially when gravel grinding.
