Jpez
Washed up zwifter
Don’t think so. Seems all screwed together well. Straps looked like towing straps.does that top bit come off with the strap handles at the corners?
But could do. (Shrug)
Don't kink shame...we can't all fit XL bikes.For dwarves?
I assume it's like pet friendly accommodation.Stupid Question: Do you think JD Vance has to pay the same extortionate
cleaning fees at a AirBNB as the general unwashed?
I see he's copping a bit of flack in the Cotswolds currently which is mildly amusing, I don't think he'll ever have a holiday in relative peace again.
Yeah those skinny wires are loving it!What are the skinny wires connected to the solar infeed doing? 12V solar panels will run about 20V and those skinny wires are getting that. Effectively you are not using the pwm controller at all and backfeeding the pwm controller. With regards to the controller some don't like to be backfed. Easiest thing is to throw a diode in the battery circuit or... ...run the fan from the battery full time and let nuclear power charge the battery when it can.
This is what I wanted to do just the fan wouldn't run when I initially connected it....run the fan from the battery full time and let nuclear power charge the battery when it can.
You can see where he trimmed the tips off the wires...I am amused by the statement ' I circumvented this '
Sorry , just made me giggle
Thought it was from an only fans channel and was worried where it was going at first
Yeah it's why the bearings and crown race are tapered.I thought that was pretty standard. It's what mine is like at least. Doesn't the stem pull it all a snug as it needs to be?
I'm measuring 0.1mm clearance between the cups and the bearings.I thought that was pretty standard. It's what mine is like at least. Doesn't the stem pull it all a snug as it needs to be?
I think there's 2 different sizes of lower cups that are 0.1mm different in diameter. I only found this out when I replaced my headset bearings and the steering locked up every time I landed a jump. How does it compare to the old bearings?I'm measuring 0.1mm clearance between the cups and the bearings.
You can rattle them side-to-side in the cups.
TBF these were the old bearings. I don't remember them being that loose when I installed the angleset.I think there's 2 different sizes of lower cups that are 0.1mm different in diameter. I only found this out when I replaced my headset bearings and the steering locked up every time I landed a jump. How does it compare to the old bearings?
