wkkie
It's Not Easy Being Green
The latest hardtail into the stable is a Waltly.
Wasn't going to be titanium (or Waltly) originally but Marino got way bad with communication so this was the result!
Frame - Custom Waltly Pinion
Fork - Marzocchi Z1 coil, 160mm, 29 inch
Headset - Brand X tapered, 44/56
Stem - DMR Defy, 50mm, 31.8 (back on shortly)
Handlebars - Spank Spike, 800mm, 50mm rise
Grips - ODI Rogue, 90mm
Cranks - Pinion forged, 170mm
Bottom Bracket / drivetrain - Pinion C1.12
Chainring - Pinion 39t, Gates Carbon Drive
Shifter - Pinion DS2
Rear cog - Pinion 39t, Gates Carbon Drive
Belt - Gates Carbon Drive, 118t
Pedals - OneUp Composites
Brakes - Shimano SLXT. XT levers on SLX M7120 calipers
Brake Pads - Uberbike Race-Matrix
Rotors - TRP, 8 inch, 2.3mm thick
Front Wheel - 27.5 inch Zerode carbon on Hope Pro-4, 32h
Front tyre - Continental Der Baron, 2.4, 27.5 inch
Rear wheel - 27.5 inch Zerode carbon on single speed Hope Pro-4, 32h
Rear tyre - Maxxis DHR2 2.4, TR EXO, 27.5 inch w. custom insert
Seat Post Clamp - Meijun (green Ali special), 34.9mm
Seat Post - PNW Rainer, 200mm, 31.6
Dropper lever - Ztto, oil slick
Seat - Dartmoor Trail V2
Cables - Uberbike braided gear and brake
Full build photos are up. Check the last post for more detailed photos.
