The UCU Traditionalists would like a chatView attachment 426423
PROTO ACW 32” — ANGEL
An idea. A prototype. The first kilometres. Follow the development of the ACW 32” as we share the engineering process behind our latest experimental platform. No marketing. Just real testing, real observations and the first lessons learned on the road.www.angelcycleworks.com
32" gravel. So... 32" road bikes next?!
It'll be interesting to see where head angle and fork offset ends up settling for 32ers. I'm intrigued to see of it's just a straight extrapolation of current forks, or is (relatively) a bit longer offset to make the bigger wheel feel a bit more reactive. Probably also going to depend if the big wheels stay confined to the XC wheel or if they make the jump into enduro and downhill (can't see them taking off in slopestyle though somehow...View attachment 426448
AliExpress 32" with AliExpress 32" wheels spotted on Chinertown forums.
Yeah 100% would be interesting to see how much effect the larger wheel has on rolling over bigger rocks on technical climbs. The rocks should hit the wheel lower down right? As it's bigger, thus making it roll over stuff more easily. That said I just don't see a full rigid hardtail 32" being much fun out on the trails even if the larger wheels do allow for slightly lower tyre pressures.It'll be interesting to see where head angle and fork offset ends up settling for 32ers. I'm intrigued to see of it's just a straight extrapolation of current forks, or is (relatively) a bit longer offset to make the bigger wheel feel a bit more reactive. Probably also going to depend if the big wheels stay confined to the XC wheel or if they make the jump into enduro and downhill (can't see them taking off in slopestyle though somehow...)
They'll hit the wheel at the same height, but at a lower 'angle of attack' where it contacts the wheel (less like riding into a gutter, lol)Yeah 100% would be interesting to see how much effect the larger wheel has on rolling over bigger rocks on technical climbs. The rocks should hit the wheel lower down right? As it's bigger, thus making it roll over stuff more easily.
Probably quicker on flow trails, rocks maybe - but not if sudden direction changes are required is my guess.Even with a suspension fork I just think it won't be more capable than a full suss 29er on more technical terrain.
If you get onto it really early, you might be able to try it and lose a minimal amount while others are curious to try. TBH though, if you're not frothing 29ers as it is 32's will probably feel horrible. The necessary chainstay lengths are probably going to make the bike pretty unwilling to have the front wheel popped up ledges for a rider of your size & weight.All speculation though! Part of me is tempted to try one of these AliExpress carbon frames out, but my gut tells me that being an early adopter of 32" wheels makes no financial sense at all.
yerp, slightly more vertical push for the bigger wheel, but in the end the axles still have to go up the same amount to get over the same rockThey'll hit the wheel at the same height, but at a lower 'angle of attack' where it contacts the wheel (less like riding into a gutter, lol)
That's...not elegant.View attachment 426448
I've gotten over my e-MTB pretty quickly and hardly ride it these days.
That would be quick on fast rolling trails and fire roads.
Needs drop bars.That would be quick on fast rolling trails and fire roads.
Easy. Just rotate the one it has!!Needs drop bars.
FTFYNeedsdrop barspetrol and a match.
I like it!FTFY
I know, burning it might be a tad extreme...I like it!
