DHX2 coil compatible?Apparently not a lot fit in to the little hookey hole that Ibis have provided due to the piggyback.
Surely you can't be locked into the X2 nightmare for life?Apparently not a lot fit in to the little hookey hole that Ibis have provided due to the piggyback.
Dunno, haven't looked into anything yet. Back from 4 day in Melrose and busy around here.DHX2 coil compatible?
Another Oso owner got 81 Spices to look into a shock to go with his new Intend fork, he came up blank.Surely you can't be locked into the X2 nightmare for life?
Looks like the coil fits.DHX2 coil compatible?
Might do, its limited by the frame shape cut out and the piggyback space.Could you fit a DVO Topaz 2 in there?
Woooaaaa... $1800 shock.
Jokes aside, I can't see much reason most shocks wouldn't fit in that tunnel. Might need to be a bit careful to ensure clearance between damper controls and the frame's trunnion mount tabs, but the X2 has a pretty big air can so if it fits you'd think most piggyback shocks would.Woooaaaa... $1800 shock.
I'll be sticking with the X2 until it gives me the absolute shits.
Then I'll go the full stroke 205x65 that ups the travel to 170mm in the rear.
Probably, I haven't looked too hard into it.Jokes aside, I can't see much reason most shocks wouldn't fit in that tunnel. Might need to be a bit careful to ensure clearance between damper controls and the frame's trunnion mount tabs, but the X2 has a pretty big air can so if it fits you'd think most piggyback shocks would.
Quoting for a fortnight from now.Not interested in changing it just yet but may be an option later.
Don't even know if I'll have the shock back then, I have the Work Order from Fox in my inbox, its scheduled to be fixed on the 19th April... then shipped back, then another 2 weeks to blow it again, maybe about a monthQuoting for a fortnight from now.
(Hopefully not though...)
Topaz 2 ? Stroke 205x65 ? Trunnion ?Did you want to put a holding deposit down on the Topaz I'm selling?
Got it... have just sent Ibis (USA) a message and asked for a compatibility list, if they have one.make your way to the For Sale thread
Hi xxxxx,
Sorry to hear about the blown shock! I'm glad to hear you are loving the Oso otherwise.
The Oso is compatible with the Fox X2, Fox DHX2 Coil (MY21 and newer) and Fox DPX2 (MY18 and newer). It is not compatible with the Fox Float X, DHX, Rockshox, DVO, or Cane Creek products. When attempting to install a shock not on the approved list, please deflate the shock and cycle through the entire stroke to verify clearance.
I have heard rumors of the DVO Topaz V3 just barely fitting in the Oso, but it's not something we have test fitted for clearance.
Happy Trails,
Chuck
that's a bit weird... Surely the dimensions aren't that different and the clearance isn't that tight???@Mattyp
Quick reply.
Considering a lot of their other bikes are factory with DVO products, you'd have thought they would have thrown one on there at some stage to test or try rather than Fox products.
I also asked specifically about your shock.
Hmmm... tight(ish)that's a bit weird... Surely the dimensions aren't that different and the clearance isn't that tight???
