AM Stanton Switch 9er FS titanium
kten
Likes Fork
Kten doesn't fuck around so my bet is Ohlins, Onyx or Formula. I doubt it will be a set of dirty Lyrics or 36s
It’s something I haven’t tried before. Another risk…but I’m quietly hoping it’ll be freaking awesome.
In the meantime I’ll be putting a greeen DVO Onyx fork on so it’s going to clash hardcore lol.
kten
Likes Fork
Another ride…another crash. Broke the AXS shifter clamp by hitting it with my knee this time…damn unlucky.
Jury is out on the Michelin front tyre. Feels soft enough to the touch but isn’t gripping on certain terrain. Roots are like fucking ice. Wishing for the DH22 compound. I had the same dramas with the previous generation Wild Enduro tyres…some love em, me not so much.
Anyone looking for some tyres?
rockmoose
Best you just send me the complete bike. I'm only concerned for your well-being.
ForkinGreat
Random Krishna
have you got the gum-x or magi compound versions of the Michelins?
kten
Likes Fork
Little update as I've changed a few more things. Ohlins TTX coil felt ok but overdamped so I've been playing around with the TTX air and again this air shock never fails to impress (my other bike takes the same size shock which is why I have multiple options to try which is somewhat of a bonus). Found I can run the air shock with no volume spacers and even with relatively low pressure and deep sag (23mm or 35% shock sag) the kinematics are progressive enough to still give decent support. If I didn't have any other shock to try I would be happy sticking with this shock....but yeah..
Cane Creek Kitsuma coil shock gives a huge range of adjustment so I figured I could back off the damping and get a really active, controlled 140mm travel with this one. Using the Ohlins 388lb spring I get less sag (about 16/17mm or 25/26% shock sag) and after a decent ride today settled on almost minimum HSC with just a touch of LSC for added support off the top. HSR and LSR dialed in just enough to keep the back end under control and it feels tight. A good tight. Feels more controlled over chatter and rock gardens than my 170mm travel bike...yes there is still feddback but it's a pitter patter of an active, controlled rear end..doesn't stall on square edges. Most of the unwanted feedback from the back end is coming from the chain/derailleur...I guess having slightly less squish, the forces have gotta go somewhere. I've ordered a 350lb spring to test.
The Michelin front tyre has taken a little to work out. I've come to the conclusion that it is a great tyre but only under certain conditions. It needs heat and/or rider input/pressure to work. If you are on it and committed the tyre hangs on in the corners really well and provides decent feedback. If you relax or don't give it your full attention it gets equally distracted and forgets to grip. Wet roots are also not this tyres friend. Like fucking ice is the best description I can give. Zero warning it's about to let go in this scenario..zero. Obviously when it's wet the temperature is normally lower, that's another consideration for this tyre....the rubber likes heat. This is supposed to be the same rubber as the DH22, my favourite front tyre....maybe the extra weight of the ebike is keeping the temp up more. Ten years ago I would run this tyre all the time....but now I'm not 'on it' all the time so I need something that stays focused even when I don't so it will get changed. The rear AM tyre with cushcore seems fine btw no complaints.
Ergon saddle had to go. Replaced with the Specialized one off my other bike and balance has been restored. Say what you want about Specialized but they can make a comfy saddle...I've ordered another one.
With the Onyx I did a damper bleed using Silkolene Pro RSF 2.5W as going by the viscosity charts this compares well to Motorex 2.5W (what I normally use but couldn't find any on the day). The fork now feels very overdamped. Normally I run with about 3 full turns of HSC from open but I've had to open that up completely and even the rebound I had to open up another two clicks. Doesn't feel bad, just like a little treacle has been added lol. Motorex has been ordered.
Sam Hill pedal shat itself today.....Deity T-Mac pedal last week....
Hopefully the next lot of changes will be the last for a while as I'd like some consistency on the bike to get more of a feel and get more comfortable for the upcoming race.
385035
Jpez
Knows which side his bread is butthurt
I’m still disappointed you didn’t get an Actofive but that is the best looking bike I’ve seen in a long time! Even with the @wkkie green fork lowers!
