It represents the number of teeth of the smallest and largest cog on the cassette.wats the difference between 11/32 aand 11/34. i sorta understand but i dont really get wich one i need. i ride downhill (or try to), so i need the larger gears... wich one do i need?
Thanks
Most I have seen use conventional cassettes, since road ones can be a bit limited. There are quite a lot of people using roadie cassettes though (not me anymore, missed the range too much).I could be wrong, but most true DH rigs use road cassettes.
First, what gear range are you using now? Do you want to have a higher top speed or are you more concerned with being able to pedal to DH tracks? If you are happy with the range of gears you have now but want to shift them all a bit higher or lower you are better off buying a replacement chain ring with a different number of teeth.wats the difference between 11/32 aand 11/34. i sorta understand but i dont really get wich one i need. i ride downhill (or try to), so i need the larger gears... wich one do i need?
Thanks
The man speaks sense. Get a Shimano XT cassette. They're cheaper, lighter, last longer and shift better than any SRAM cassette. I love my SRAM gear but their cassettes aren't up to Shimano's standards yet. An example, 11-32 PG-990 is claimed at 275, most weigh 290, even with the aluminium lockring they come with. XT 11-32 claimed is 264 and that's using a steel lockring, my current one when new with an aluminium lockring was 250 grams.If you want to go a step up in cassettes, check out the Shimano XT M760 cassette. It's nicer than the PG-990 imo, and tends to be a little cheaper too.
