Spank spoon pedal bushing removal
PJO
in me vL comy
Anyone done a pedal rebuild on Spank Spoon pedals?
What's the best way to remove the bushing from the pedal?
Don't know about Spank 0edals in particular but I use an appropriately sized drill bit to get bushings out of my Time pedals.
teK--
See if you can find a course thread bolt that is slightly larger than the ID of the bushing. Wind it in then fix the bolt in a vice and pull up on the pedal.
Boom King
Pretty sure they're a nylon bushing so just pry it out with a screwdriver or pull it out with a pick or such like. That's, of course, assuming you are changing it for new.
Sent from my SM-G960N using Tapatalk
  • Like
Reactions: PJO
What I mean by drill bit is to use a drill bit that is slightly larger than the id of the bushing. Screw bit into bushing then use a set of pliers to pull it out.
PJO
in me vL comy
Thanks for the clarification.
I thought you meant push it through form the other side, which isn't possible with the spoon pedal I don't think.
