YepYou’d be paying somewhere between 20 and 30c per kWh so looks pretty good to me.
It definitely could be better....Turns out the system hadn’t connected to device or net since Nov 2022, took me 3.5 days to download the data.
First day of data under the new owner, aircon switched on at 12. 27 panels each with its own micro inverter. Half on east side, half on west.
What is it about roofs in Canberra, especially those from 5 years back that limits them to around 2.5kWh? And sorry, not sure what you mean about avoiding the air con.It definitely could be better....
That's not a big output. Though I'd be surprised if any roof area in Canberra could manage more than 2.5 kWh. Especially five years ago...
We've got a 5.something array (let's call it 5.2 kWh) and it's flat out and pinging at 4.8 through a Fronius inverter.
Time to work on the things that avoid the air conditioning...
The typical Canberra detached house is a bit smaller than the national average and the panel efficiency wasn't so great either.What is it about roofs in Canberra, especially those from 5 years back that limits them to around 2.5kWh? And sorry, not sure what you mean about avoiding the air con.
I'd like to think that solar and a/c comes last but the cost of retrofitting high performace glazing is (at least in Perth) likely to be significantly higher cap ex that solar - A/C probably a given in any case, just have to bump up the system for poor performing house. I put in double glazing anyway but cost benefit ratio is not there - might be different in vic/tassie where heating a bigger factor, maybe Canberra too!The typical Canberra detached house is a bit smaller than the national average and the panel efficiency wasn't so great either.
As for the air con comment, solar and battery etc is the last step in the efficiency upgrade process. If you make the house itself operate using the least amount of energy input (insulation, good windows, best use of the environment it sits in) in the first place then everything else afterwards comes cheaper...
It's called a hybrid inverter, one for your needs will set you back about 3 grand.What i would need the inverter to do in the event of a power outage is to have the capability to run the house off solar (Should there be enough) instead of what on grid inverters do whereby the power goes out even during daylight hours.
I'm hazarding a guess the cost of this would be about 8-15k
In Perth, based on a lot of what I saw 20 years ago, it's probably be cheaper to just demolish and start again!!I'd like to think that solar and a/c comes last but the cost of retrofitting high performace glazing is (at least in Perth) likely to be significantly higher cap ex that solar - A/C probably a given in any case, just have to bump up the system for poor performing house. I put in double glazing anyway but cost benefit ratio is not there - might be different in vic/tassie where heating a bigger factor, maybe Canberra too!
My place is 70+ years old, building anything in Perth costs approximately $1Billion so I'll keep it for nowIn Perth, based on a lot of what I saw 20 years ago, it's probably be cheaper to just demolish and start again!!
Demolish Perth and start again? I'd support that.In Perth, based on a lot of what I saw 20 years ago, it's probably be cheaper to just demolish and start again!!
I'm not sure Perth is much different to most australian cities, some more older stock in Syd and Melb obvs but that doesn't reflect most of it. The main difference is due to some local materials and clever marketing we have a LOT of double brick houses rather than brick veneer.Demolish Perth and start again? I'd support that.
What got me was the use of broken bricks, used condoms and spit to fabricate non load bearing internal walls. Several,places we looked at you could move the wall leaning against it.I'm not sure Perth is much different to most australian cities, some more older stock in Syd and Melb obvs but that doesn't reflect most of it. The main difference is due to some local materials and clever marketing we have a LOT of double brick houses rather than brick veneer.
It's gotta be more than that as the export for a day is nearly 50kWhThat's not a big output.
So I signed up for a big battery
Leave the windows open when the aircon is on. Grow hydro. Although with the price of medicinal it would hardly be worth it.any tips on utilising the load?
40kWh, Maybe 200w continuous overnight, air con is drawing about 4-5kW if it's summer for about 2 hours after the sun goes down. Nothing else running overnight but soon probably EV charging.How big? How much power do you use at night?
Wife already on to it. Has been doing this since forever. Wants fresh air but also conditioned...fml.Leave the windows open when the aircon is on.
Thinking aquarium, heated tropical fish. Second fridge/ freezer - a cheap nasty inefficint one, leave the door open on 40C days. Few bunnings resistance heaters scattered around the house.Grow hydro. Although with the price of medicinal it would hardly be worth it.
Better off charging through the day. Nothing else running overnight but soon probably EV charging.
Yeah that's the plan, but behaviour change is a real challenge with the other half.Better off charging through the day
