$45 for a four-pot caliper seems really cheap am I missing something.Not much more than $200 for SLX 4pot on bikebug, sans hoses.
Fixed/updated.
Can you fix your tag?Fixed/updated.
#NitpickingCan you fix your tag?
prob belongs in stupid Q but an i run 4 pot ali-era with normal levers, sme jose diameter right? i owuldn’t mind a couple of 4 pot for font brakesNot much more than $200 for SLX 4pot on bikebug, sans hoses.
Do you know if the calipers come with the Banjo bolt? The bolts required for the BR-M7120 are the same as the XTR (M9120 I think) ones, but can't seem to find them anywhere for sale separately online.I've got no idea on why they are so cheap. The levers I got have arrived already and look bloody good for $50 ish. The only downside I can see without using them is that the lever blade itself looks and feels a little cheap, can see the machine marks on it (from being stamped I guess?) and its not dimpled like the XT ones I used to have.
The calipers are coming in a separate package and are due "end of august", which I wish was made clear during the checkout process. To me, it read as if they were a special order item, i.e. maybe a week or two max wait. Turns out that they hadn't actually been manufactured yet... I feel like it should have been labelled a pre-order. Lucky I've borrowed some codes in the meantime.
Yes same diameter Jose. Oh wait isn't your name Daniel, maybe I'm Jose.prob belongs in stupid Q but an i run 4 pot ali-era with normal levers, sme jose diameter right? i owuldn’t mind a couple of 4 pot for font brakes
Banjo bolt is supposedly different to the one you just got, the hose is compatible just not the bolt.Lever came with only the lever itself and the rubber shroud thing that covers where the hose enters.
Shimano website (here - https://bike.shimano.com/en-NZ/product/component/slx-m7100/BR-M7120.html) lists the compatible hose as being the SM-BH90-SBM. So I also got two of those from bikebug, 1000mm and 1700mm. Interestingly, they came with several pieces not listed on the front of the packet - another one of those rubber lever shrouds, and the bolt that goes into the caliper.
Pretty sure once the calipers arrive that's everything you'll need?
Ahh yes okay, well yeah, I hope they come with the bolt!Banjo bolt is supposedly different to the one you just got, the hose is compatible just not the bolt.
