Sealant thoughts
I can confirm Gippyz Gooey Goop worked. Injected it to a tyre that wouldn't stay inflated - likely because out of sealant, and it is now staying up. Also setup 3 new tyres on 3 different wheels and they all stayed up. The coffee granules worked miraculously well.
Coffee granules as in, spent coffee grinds?
Might have to try it next time.
I'm interested to see if the coffee grinds don't clump together as much as the rubber grit does....
From W-mart (workplace).
Pretty sure you can buy individual rolls here...
Ahhhh, yes, same place I used for isopropyl and other industrial grade solvents.
Had to find a new mart and this one had nothing related to bikes at all!
I love this, if it works as well as, and replaces glitter you have come up with a nice environmental win.
How fine do you grind your coffee? I'll try it with a different grind size.
My grinder is set at 13, and i haven't touched it since i bought it. The grinder has 1-16 setting, with 16 being the coarsest.
Squirt Bead Block Sealant
This stuff was on special at Crooze, alas the name does lend itself to the above post .
Its got a bottle of magic bead block particles ?
Time will tell
I only use proprietary brands like Stans or Vittoria both are OK.
I suppose everyone has problems with sealants .
The valve jams open and the tyre goes flat .
The valve body gets blocked .
If the tyre has been in place for ages it gets almost welded to the rim so you cant get it off in the bush to put in a tube so you have to use plugs .
Plugs dont work so well in thin sidewalls and when that happened a friend who likes tubes joked about tubeless I said " This is a friendly Fuck Off ''
I walked out . It took me about 1/2 hr to get the tyre off at home.
Other than all that, i am keen on tubeless.
Time will tell
I've just finished a bottle of Squirt sealant. I figured I'd give it a go as I'm a big fan of their chain lube.
Overall it worked fairly well, maybe with a slightly faster evaporation rate. I did notice the beads aren't really enough for every time I poured sealant in, I ran out of the gritty stuff a few tyres before the bottle was done.
I've just grabbed a bottle of Joes, so I'll see how that compares in the next 6 months. Look for the COFW post around then when I've compared one if each tyre, and ended up wtih a flat at the further point from the car 🤣
