Yeah I was thinking I need to up the glycol a little.Mate, I have had no reason to unmount a tyre with my special seed inside so have NFI. I don't want to splooge stains all over the garage floor if I don't have to!
I suppose more glycol will prevent boogers?
So can we just use cheap cloudy ammonia from Coles for $2? #notachemistI found adding the propylene glycol caused my mix to form boogers. I don't use it anymore. Windex (for the ammonia) stops the latex going off. Whe it dries out it forms a nice even coating on the inside of the tyre which provides some puncture protection even if dry.
I'd be worried about the detergents in cloudy ammonia having a negative effect.So can we just use cheap cloudy ammonia from Coles for $2? #notachemist
Probably. I got a 5L container of the Windex from somewhere ( maybe Supercheap) and it was pretty inexpensive.So can we just use cheap cloudy ammonia from Coles for $2? #notachemist
Righto, $20 at Officeworks/Bunnings seems like a pretty good deal. When I've used the 1500ml of glycol based stuff up I'll give that a crackProbably. I got a 5L container of the Windex from somewhere ( maybe Supercheap) and it was pretty inexpensive.
So I had a sealant fail tonight unfortunately.
Got a small sidewall slash and the sealant didn't seal it up.
Now, I don't want to jump to conclusions and it's no guarantee but there is a slight chance that the sealant failed because it had all dried up and I didn't have any fucking sealant in the tyre. Fuckwit.
Just in time for me to mix my own 1st batch next weekend. Will be picking up the stuff during the week. Can't find any rubber dust or granules anywhere, and neither do i have old tyres to sand. So going with ground coffee, dog hair, and corn starch. Will report back when i get to mixing it.Refreshed the sealant in my rear tyre with a new batch after I found (via a sidewall slash) that it had all dried up last ride.
Sealed the sidewall slash instantly, will be interesting to see how the slash goes with some ride induced sidewall flex.
Tweaked the recipe a bit with some more glycol.
150ml batch 22/0226:
60ml PG antifreeze
45ml demineralised water
45ml latex
1.0 teaspoon of bio glitter
2.0 teaspoon of rubber dust
Interestingly, I still haven't seen any valve stem corrosion like @wkkie had. Not sure what the difference is in this case.
Where are you based?Just in time for me to mix my own 1st batch next weekend. Will be picking up the stuff during the week. Can't find any rubber dust or granules anywhere, and neither do i have old tyres to sand. So going with ground coffee, dog hair, and corn starch. Will report back when i get to mixing it.
MelbWhere are you based?
Yes pls. Pm me his deets. I can swing by otw to work.If you don't mind a drive to Moorabbin I can send you the details of a guy who will sell you rubber crumb for next to nothing
Made a litre batch using this recipe and ground coffee. Didn't have the time to buy some rubber crumbs. So will test this first. If it doesn't work, will buy some rubber crumbs and pour them in.Refreshed the sealant in my rear tyre with a new batch after I found (via a sidewall slash) that it had all dried up last ride.
60ml PG antifreeze
45ml latex
Nice! Gippyz Gooey GoopMade a litre batch using this recipe and ground coffee. Didn't have the time to buy some rubber crumbs. So will test this first. If it doesn't work, will buy some rubber crumbs and pour them in.
Haven't poured them into the tyres yet. Will do so later this evening after i come back from a ride.
View attachment 422923 View attachment 422924
I can confirm Gippyz Gooey Goop worked. Injected it to a tyre that wouldn't stay inflated - likely because out of sealant, and it is now staying up. Also setup 3 new tyres on 3 different wheels and they all stayed up. The coffee granules worked miraculously well.Nice! Gippyz Gooey Goop![]()
