SummitFever
I've ridden Stromlo every Sunday morning for the last three Sundays and have used three different 1x configs with a 32t front chainring:
(1) 11-34 10 speed;
(2) 11-40 10 speed;
(3) 11-48 11 speed.
Each time, we've done a pretty similar ride. 3 times to the top via every crazy route that Jeebus can invent (except going up the traditional route) and then down Vapour, Pork Barrel + Double Dissolution or Skyline in various orders.
It's been interesting using the three different cassettes.
The close ratios on the 11-34 are great. A good gear for every occasion and the 34 is large enough that all the techo stuff can be cleared but you burn a lot of energy with only having a 34. 3 times to the top of Strommers in a row is fine, but if I had to do it 10 times it would probably break me.
The 40t on the 11-40 does not feel much easier on the climbs but it's got an annoying 3t jump in the lower mid part of the cassette at a speed where I spend a lot of time on the single track. Gives me a sort of Goldilocks feel - cadence either too slow or too fast.
The 11 speed 11-48 is better than the 11-40 as the 48 means you can spin up the steepest stuff and smoothly get the power down up technical obstacles. It does have similar larger jumps between gears like the 11-40 but interestingly its not in the position that I personally find annoying. It is also still not low enough for me on a 29er with big tyres.
Conclusions
I'm about $600 into this "experiment"
- $200 for an XTR 11 speed RD
- $100 for the 11-40 cassette
- $320 for the 11-48 cassette
so I should be gushing to you all about how great 1x drivetrains are but 1x sort of sucks. I "get" all of the advantages but for me there's just too many compromises. I like a gear for any and all occassions and the wide ratio cassettes don't give the range of a 3x setup nor the in-between gears that make for efficient riding.
I don't get off and walk my bike no matter how steep things get or how long the climb is. I also don't drive to the places I like to ride, so Stromlo is a 30km+ bike path round trip from home. I need an efficient drivetrain and the 1x stuff is probably never going to be able to deliver that...
Reality check
While I prattle on about efficiency and gear range I'm duty bound to point out that Jeebus (Brett Bellchambers) has been doing all of these Stromlo rides (and smashing the climbs) on his single speed with 32-21 from memory. Each to his own.
(1) 11-34 10 speed;
(2) 11-40 10 speed;
(3) 11-48 11 speed.
Conclusions
Reality check
