I recall many a time lying flat on my back under one of those...fingers aching and winded.I see my old friend the campus board there as well.
For top roping in a gym, bina through the main loop, and rope through loop at the legs, then through the main loop and tie off.Ok, picked up some gear today, Scarpa Velocity shoes and a Black Diamond Momentum DS. I'm not used to harnesses with the belay loop as a ring joining the leg and waist straps. What's the proper way to hook in two carabiniers to this style of harnes?
That's how it's set up in the gyms. One on figure of 8 at the bottom and one maybe 20cm higher up the rope. No need at all to do any sort of tying off. For the hire harnesses I clipped them both through the belay loop going the opposite ways. Belaying is just one attached to a grigri so I've got that sorted.For top roping in a gym, bina through the main loop, and rope through loop at the legs, then through the main loop and tie off.
If you're leading, tie your bowline (or fig 8) through both loops.
What are you using two biners for?
^ Bad gym, very bad gym.
Always tie through the harness as described above using a figure 8 (bowlines can come undone).
Yeah hence the stopper. Fig8s are great, in that they're a simple and bomb proof knot, but trying to get them undone after a whipper is a balls ache. (Most gyms won't let you use a bowling anyway :/)^ Bad gym, very bad gym.
He has just bought shoes and a harness so I think it is fair to say he isn't leading anything at the moment - and every gym I have climbed at requires you to bring your own lead rope and tie in.
For top roping most gyms have 2 carrabiner clip in these days which is simply to double the chances of somebody clipping in properly. Put the first carrabiner through the tie in loops on the waist and legs, with the second carrabiner ideally you do the same thing or put it through the belay loop if you run out of room.
Why the tie in loops? I've read that you're limiting the effective strength of the biner by cross loading it and that they were designed for 1 point of contact (not counting the rope) rather than two.Yeah hence the stopper. Fig8s are great, in that they're a simple and bomb proof knot, but trying to get them undone after a whipper is a balls ache. (Most gyms won't let you use a bowling anyway :/)
And yep, top roping I always clip in with a Bina and tie through both loops. I'm weary of gyms that use gri-gris too.
Tie in loops? Good habbits more than anything else, the belay loop is strong enough.Yeah, I'm only top roping. Two biners and a gri-gri is how all the gyms I've been to are set up. I'd much rather tubular but they cater to the general public too.
What grade would you recommend to be comfortable at before I look into lead climbing?
I reckon Gri-gri's are fine; they're no more nor less dangerous than your standard ATC, provided you learn how to use them correctly and understand their limitations. I prefer a gri-gri for aid climbing and TR though usually use an ATC for lead. As far as when to get into leading that'll depend on a few things; most important is a solid climbing partner who can show you the ropes? One way to get your mind around the leading process is to "lead" while on top rope. If you have a party of three, one of you can "lead", one can "lead belay" and the other one is actually belaying you on TR. You're not actually leading because you're still on TR belay though as a leader you get a feel for clipping while your "lead belayer" gets the hang of paying out slack, watching for you to clip and taking up slack in a dynamic way. I personally reckon the best skills to focus on learning is lead belaying and communicating with your partnerYeah hence the stopper. Fig8s are great, in that they're a simple and bomb proof knot, but trying to get them undone after a whipper is a balls ache. (Most gyms won't let you use a bowling anyway :/)
I probably should have addressed this in more detail, there are a couple of things at play here.Why the tie in loops? I've read that you're limiting the effective strength of the biner by cross loading it and that they were designed for 1 point of contact (not counting the rope) rather than two.
You do not learn to climb on the internet - This is rule 1 of learning to climb.which is more reliable than randoms like me on the intenet
My belay style is quite similar to this although my free hand ends up on top in 3 and I release and regrab with the brake rather that slide in 4. I originally learnt on tubular so was lucky not to be poorly instructed.2 - I haven't seen you climb or belay but most people in climbing gyms can't belay for shit, belaying on biners is totally different to slow-go-s or what ever device the gym uses to make belaying easier - be prepared to improve your belaying - if you are using tubes or sherrifs you will need to lock down properly, you will need to communicate with the climber and understand when they need slack or for you to take up quickly - you will need to belay not just drag a rope through gri-gri.
