So Jeff the truck is still getting worked on, parts coming in thick and fast.
One issue I've run into (and would like some feedback on) is that I couldn't get replacement drum brake cylinders from Repco, so I assume Supercheap and Autobarn will be no use either. So I ordered some online, and they bolt in perfectly, but the thread where the brake hose goes in is one size too small (M8 instead of M10 I think). To save heaps of fucking around calling and visiting heaps of different places, I'm thinking of removing the piston from the bores, drilling out and re-tapping the threaded line connection (ensuring to not damage the bore that the piston slides in), cleaning thoroughly and reassmbling. Obviously I'd do a check for leaks with someone standing on the pedal hard before using, maybe even use some PTFE tape to ensure a good seal.
Thoughts?
I've also got the eldest (7 y/o) out there learning how to swing spanners and what various parts do. It sucks listening to Taylor Swift while working instead of a podcast or SOAD or something, but a great time still. Photo of her removing a clutch line, and another of her first mechanic's scratch.
Thoughts?
TBH if the truck has been sitting a while then I'd probably just replace the hard lines as well. Which means you can convert to M8 fittings.
Gave the ST a decent run on the weekend. Tyres are rubbish (RE003s). Many yellow lights flashing. Speedo is wildly optimistic but it goes ok. Obvious step up from the XR4.
It's worth a look at the other's. My work is effectively auto electrical and I'll start at Repco, but if it's not there one of the other two normally have something I can use. I'm also dealing with new, not classic parts though.
If you're not already, keep an eye on NAPA too - they can be handy for auto-elec bits. Prices vary but trade discounts can be significant.
Quoted for future lolz. :p
It's an Edition 507 so I don't really want to hurt originality or resale.
However, there is a company in the states that have perfect the manual gearbox swap :p.
Watched a few long tube header install videos recently. I have a hoist and even then, it looks super painful to do!
Had the new tyres fitted to the rims yesterday. I bought metal valve stems and new tpms sensors because the originals are 10 years old. Asked the tyre place to confirm new were same as old by stripping an old tyre. Hmmm. No tpms. Hmmm. I had to do a reset for my mate a few weeks (months) ago so wtf? This model uses the abs unit to detect rotation speed differences to trigger the warning.
"The Deflation Detection System will alert you if there is a change of air pressure in any tire. It does this by using the ABS sensors to detect the rolling circumference of the wheels. When the circumference changes, this indicates low pressure in a tire, a warning message is displayed in the information display and the message indicator will illuminate."
This explains why the local Ford place wrote about an abs fault when it was in for the last service and the tyre pressure warning light was on. You would think that the dealer service group would know about this system and check tyre pressures and reset the system. Alas no. Anyway I have 4 tpms sensors... from what I read I could configure these to the bcm and reset the abs unit. That is too much like hard word and this way I can borrow the track Fiesta's non road legal semis should I feel the need.
