Looks more like a latte to me.Not unless Cappuccinos have composite tubs and ground effect aero.
Has almost the exact dimensions of a Lancia Stratos, so tiny but somehow managed to fit me, just.![]()
I’m so glad you got this.Not unless Cappuccinos have composite tubs and ground effect aero.
Did I mention it's got a second seat and Liddenham allows passengers?I’m so glad you got this.
Genius!Gotta say I was impressed by this.
How good was this video from @sidewaysc33 on TikTok . Something I now do ever since I saw this. #greatidea #gearboxbong #inventer #48tools | 48Tools | 48tools · Original audio
How good was this video from @sidewaysc33 on TikTok . Something I now do ever since I saw this. #greatidea #gearboxbong #inventer #48tools. 48tools · Original audiowww.facebook.com
You won't fit in that seat? Looks like you miss out.Did I mention it's got a second seat and Liddenham allows passengers?
The bad news is the second seat is a tiny Tillett B4.
So what you’re saying is it’s time to cut weight and take up yoga. DoneDid I mention it's got a second seat and Liddenham allows passengers?
A bit late now, but the CONTISPORTCONTACT 7 is getting rave reviews overseas. Apparently it is incredible in the wet and has better sidewalls than the Michelin's. Will be the next street tyres for the Godzilla.As the blue car is in hospital waiting on heart surgery we are down to two cars. Really sad situation that. Thus the wife is driving the m2. As that was a family car and pretty much just a town commuter it ended up on Federal something or other tyres that were fitted about 5 years ago when the V720s wore out. Wife comes in last night and asks are the tyres ok? It spun out on her and was pretty much no traction with lights flashing in the rain. So I had a look. Tyres had plenty of tread but that tread sat between sapphire and diamond on the mohs scale. So today it got new rubber. Michelin PS5. Decent tyre but criticised for its soft sidewalls and thus lack of feel unless pressures are higher than normal. Seem ok on a light car. Good soft rubber and plenty of rain gullies to shed the water. A definite improvement.
I have had several unlikes of Continental products (3, 5 and 6) and while it is only a 6.7hp fwd and more a pixie than a godzilla I could not do that. Like the D word. Plus they were more expensiver. The Goodyear F1 asymmetric 5 and 6 were an option at the same sort of $.A bit late now, but the CONTISPORTCONTACT 7 is getting rave reviews overseas. Apparently it is incredible in the wet and has better sidewalls than the Michelin's. Will be the next street tyres for the Godzilla.
No thought to go frameless an full composite construction?laid the first sidewall down with Teroson MS939 adhesive using an air sausage gun... fun times.
I did look into all of that but decided on meranti and ACP, gave me more room and time to change/ rearrange if needed... roof will be single styromax panel.No thought to go frameless an full composite construction?
What's your target weight? Length? Battery? Nuclear? Management system?I did look into all of that but decided on meranti and ACP, gave me more room and time to change/ rearrange if needed... roof will be single styromax panel.
We use the same awning more or less, ours is square both ends. There is a video by supapeg of it fitted to a jawa camper. Worth the watch. By on demand do you mean instantaneous gas? Not allowed to fit these inside. We have the webasto gas and it works fine. Be aware new gas regs require two vents (roof and lower door) for gas hws in the camper. We block ours in transit with a cut off pool noodle from bunnings for the roof vent and a sheet of foam for the door. No dust ingress.so axle/ stubs/brakes are rated to 3T in the build, hitch and plate etc is rated to 3.5. don't hold me to this >.....but we are projecting around 2/2.3t unladen (Tare) this could change but I hope we get closer to the 2T. Interior will be fabbed from lightweight caravan spec laminate sandwich board, minimal luxury items. BMS either Enerdrive or BMpro, on demand gas hot water system, lithium and Elons starlink for coms. External will be a full batwing type annex from supapeg here with full sides to suit, full ext kitchen/pantry etc. using this water use system indicator .A long way to go , just keen to get sides/rear wall installed for now.
Mate has one on his portable block of flats, says it is good. No dust issues so far.Dunno how good they are but found a neat solar powered vent fan for roof,trying to get specs on air flow ...this being for gas regs..
