Haakon
has an accommodating arse
Had one of those cheap air compressor fed Venturi type vacuum pumps, and was only able to hold about 15-20 inch hg vacuum. So I still have air in it I guess - probably a bit of moisture too…. Low side was 30-35 psi which is way too high for HyChill.
Evaporator icing over on the trip down - stupid cold air for 20 minutes, then no air flow at all. Turn compressor off for 5 minutes, nice and cool as the ice melts, and the ac back on. Repeat
Time for a proper vacuum pump and regas it again!
