The Jimny has been intermittently hiccuping at idle for some time now. No error codes are thrown.
It doesn't stall but doesn't fill you with confidence either. All fine when driving with some throttle so it is something funky with the idle airflow/fuel mix. Mrs wasn't a fan and didn't want to drive it but wasn't going to get far with the manual Mazda either
Mechanics seem to have a shotgun approach and replace coils, spark plugs, MAF sensor, PCV valve etc as likely culprits but not knowing if it will fix it 100%. Possible small holes in vacuum hoses is another one. Couldn't put my finger on what it could be overall and didn't want to just throw money at it either without knowing that it will make a difference. Seems to be an issue with Suzuki engines but no clear root cause.
I cleaned the throttle body butterfly valve where it felt a bit goopy and sticky. I guessed it could be sticking while the ECU thought it was an another angle hence the cough at idle. Seemed a bit better for a few weeks then it came back. Doh, but in hindsight was a hint.
Took it out yesterday and it hiccupped more so had to look at it again this morning.
Pulled off the PCV valve and cleaned and degreased it. Got some Nulon throttle body/carburettor cleaner and cleaned the throttle body and the idle control intake. Sprayed a bunch of it in, started it and then rinse and repeated.
All good so far and it feels smoother with more power, well a bit more. I hope I'm not speaking too soon again but a $20 cleaner vs. a $900+ MAF sensor is a good start.
None of this fun will happen with electric cars, errr....... right....??
