John U
MTB Precision
I am a firm believer that, within reason, any problem can be solved with existing standards using innovation and good engineering. There are exceptions but the rest is marketing bullshit. I do believe that changes in wheel size has been a consistent giver/performance gain in the new standards field.
I'll start if off with the 15mm axle. It's been done to death but I'm not convinced. If it was worth doing it could've been done with existing 20mm axle standard. If people need a new axle standard so they can differentiate between types of bikes they should give up mountain biking and stick to golf. Thanks Fox and Shimano, as they say in the classics, 'Ordinary people, the lot of you's'.
Backing it up with the tapered steerer. If it was required the the existing standard of straight 1.5 could have been used. I'm not sure who was responsible for this clusterfuck. Please fill the gap if you know. The same goes for you as goes for Fox and Shimano in the preceding comment.
I believe there's some discussion on rear axle standards. I'm still rockin' 135 mm out the back so have now issues here, but if you do, go to town, let it out, and let them know we will be slightly averse to swallowing new standards forced upon us.
