link1896
Mr Greenfield
Item: Oury "Mountain" grips
Purchased From: Jenson USA http://tinyurl.com/mmudsrh
Purchase Price (approx): $14 AUD excl delivery
Usage: On all of my bikes, XC, DH, bike path.
Pros - The most comfortable grip I've ever used.
Cons - They will rip if you smash, they are soft.
Comments: Iv been using Oury grips for 25 years. I still have a pair I use that are 16 years old. They are a very soft rubber, if you lay the bike over at speed they will rip. You need to use bar plugs, even thought the grips are enclosed at the end. Installing them is best with compressed air. Warranty is void if you use a glue. I've never had an issue with slippage when wet, others have. I find they stick like shit to a blanket on carbon bars.
114 mm long 114 mm circumference* 22.225mm I.D. 32mm O.D.
141.5 grams
The lock on versions are not as comfortable due to reduced thickness.
They are often imitated by the Chinese, but why would you when the real deal is so cheap.
Manufacturer webpage: http://www.ourygrips.com/mountain-grips-1/
Pictures:
141.5 grams
Pictures:
