Oops!...I Did It Again. Yeti ASR
, or maybe a dropper post.
I know plenty of people riding trail and enduro mtbs a couple of times a week.
A different bike won’t change your riding habits mate, I’m sure you’ll be ok hahaha.
This is a pretty standard loop I ride 3-4 times per week. My experience of other riders around the SoHo area is that they consist of 15yo kids smashing laps on ebikes I couldn't afford, or 50yo kids on ebikes smashing more beers than I could afford at the pub at the bottom. I'm not convinced I'd head out as often to do 1000m of climbing on an enduro bike....
I didn't realise you were in Tasmania now. My perception is we at least used to ride similar bikes on similar trails, so in that context, every big Tassie park has had at least one feature where I've wanted a bit more travel, or maybe a dropper post.
To convert a Victorian XC bike to a Tassie XC bike you need to: 1. increase front rotor by 20mm 2. add 2 extra pistons to your brakes if over 80kg for heat management 3. add a dropper post and 4. increase to 2.4 inch tyres.
I would love to change to a Fox 34 SL 130mm to test a half degree slacker head angle and proper Grip X damper too.
With your fitness, I don't think it will make as much of a difference as you think. Maybe 20min added for your loop. Less on a trail bike.
This is as close as I could find to match elevation on my enduro bike. Was much less fit than you at that time I imagine.
Good thing I wasn’t telling you to buy a enduro bike then? You like XC bikes, i get that. But damn you must be sick of breaking frames.
That nicolai is 400g heavier than the yeti. I dare say it’ll be stronger, Nicolai know how to make bikes outta metal. How much worse will half a kilo be? It’s still a XC bike with kinematics designed with pedalling efficiency at the forefront.
No idea about the Devlin weight but 120mm travel both ends is becoming the norm for XC so is it a full weight weeny frame or has he made it to handle people wanting to send a xc bike down at Maydena? Can he whack on some extra bracing to make it a little stronger without messing with the ride quality you’re after?
I think u just need a bike that’ll last 12-18months. And a carbon yeti no matter the model will not be up to the job.
I’d go the Saturn, or if u can swallow the unjustified expense a devlin (but Fark me $8g for sum gas pipe) at some point the constant swapping of frames will eat into the most valuable resource, which for you is time.
Well well well.......
1. Tick!
2. Tick!
3. If I ever move there
4. Tick!
I'm sure there's a dropper post in the shed somewhere. 😆
There have been some very cool bikes getting released in the last week. The Pivot Mach 4 SL, Ibis Ripley SL and the updated Transition Spur all look like my jam.
I spent the day doing 8 runs at Maydena which was a nice way to bring up 1000km since finding the suspicious "crack" in the rear triangle.
If after 1000km of riding in Hobart including a Maydena day (that is a total of 33,000m of descending) the "crack" looks the same, then I'm going to ignore it and keep riding.
I'll try to get some photos in the daylight in the next few days.
*I definitely did not get 8th on Maydena Hits, that is a Strava fart as I wouldn't dream of riding that....
**I did jump that tiger snake on my first lap though. What a way to shake out those first lap jitters.
So my brake lever has been leaking for the last month or so. I contacted Trickstuff and they told me which seal kit to order to replace all the seals.
Unfortunately, I took apart the lever today and found this. Turns out the seals looks okay, but some dirt has managed to get into the cylinder bore and scored the shit out of it.
Finally got around to doing a warranty claim on the cracked rear triangle with 7500km on clock. Yeti was amazing as always and posted a new one based on the photos I sent in, so I only had one day off the bike while I did the swap.
I've also fitted a Fox 34 SL. I'm super keen to see how it goes in Tassie with 130mm up front which will slacken it to 66 degrees and an actual for real life damper (Grip X). It also got a new handlebar, headset, saddle, cassette, chain, cables, shock hardware, frame bearings and bottom bracket. Spooky quiet on the shakedown ride today after sounding like a filing cabinet full of spanners for the last month.....
