Spike-X
Grumpy Old Sarah
Had a small windfall this week, which allowed me to finally get the new Sight I've been dreaming about for a while.
FRAME: Aluminum All-Mountain, 150mm Travel, 29"
FORK: RockShox Lyrik Ultimate RC2, 160mm, Charger 2, 42mm Offset (29")
REAR SHOCK: RockShox Super Deluxe Select+ RT, DebonAir 2, 185x52.5mm Trunnion
HEADSET: FSA #57 E Sealed Bearing
CHAIN TENSIONER: e*thirteen TRS Plus Aluminum, Bash (never had one of those before!)
SHIFTER: SRAM GX Eagle
DERAILLEUR: SRAM GX Eagle
CASSETTE: SRAM Eagle XG 1275, 10-52T
CRANKSET: SRAM GX Eagle, 32T, 170mm
BOTTOM BRACKET: SRAM DUB, BSA Threaded
GRIPS: DMR DeathGrip A20 Soft, Thick
HANDLEBAR: Deity Ridgeline, 800mm, 25mm Rise (may cut down to 780)
STEM: Alloy, 40mm Length, 35mm Clamp (may change to 50mm, cockpit feels just a touch short)
SEAT POST: One Up 34.9mm, 180mm
DROPPER LEVER: One Up 1x Lever (don't love it, will probably replace with Wolftooth)
SADDLE: Fizik Alpaca Terra, Wingflex
BRAKES: SRAM Code RSC, 4 piston, Metallic Pads
ROTORS: SRAM Centerline, 200mm F/180mm R
FRONT HUB: DT Swiss 350, 15x110mm Boost, 6 Bolt
REAR HUB: DT Swiss 350, 12x148mm Boost, XD, 6 Bolt, 36T Engagement
RIMS: e*thirteen LG1 EN, 32H
SPOKES/NIPPLES: DT Swiss Competition DB Stainless Black
FRONT TYRE: Maxxis Assegai 2.5" 3C Maxx Terra, EXO+, TR
REAR TYRE: Maxxis Dissector 2.4" WT 3C Maxx Terra, EXO+, TR
PEDALS: Shimano Saint PD-M828
Only had time to install pedals, set up the cockpit and begin bedding in the brakes today. Tomorrow morning will be setting up tubeless, getting suspension sorted with the RideAlign site, and tomorrow afternoon...WE RIDE!
