The second motor is more about changing the speed difference in the planetary gears to create the different 'ratios' than "adding power". It's just different packaging of the motors at a guess.I’m not sure how the Avinox motor works but the Gobao uses two motor. One to turn the chain ring and one that takes the input from the cranks and adds that power to the other motor.
Would almost certainly just be stuck in whatever ratio it is in when the battery drops below minimum Voltage and so sad too bad. Might have a threshold where it goes into a limp mode.Not sure how that works with a flat battery.![]()
