MarioM
My new XC race machine replacing another Merida ( 96 ) .I was going to take my time with this build after getting the frame from Johnny Sprockets but the forks and wheelset came in the too good to say no to price bracket . This is my first 29" bike and its so damn quick . The spec will change as I borrowed some parts from the 96 to put this one on the trail . It had its maiden voyage today and was able to compare the ride to another done on the 96 just recently . Over the same course the big 99 was 3 min15 sec faster than the 96 with a lot less effort and I wasn`t pushing it , just trying to get used to it . I felt instantly comfortable on it when I sat on it and after 3 laps I was used to it . I love having remote lockouts back .
Changes will be going to 700 mm bars and I`m thinking maybe a 32 tooth front ring .
Frame - Merida Big Ninety Nine
Rear shock - DT Swiss M212 remote lockout
Front shock/fork - Suntour Axon Elite with ti axle and remote lockout
Handlebars - FSA SLK Carbon 680 mm NOW 3T Pro flat 720 3 deg alloy bar
Stem - FSA SLK alloy ? with carbon face plate . The ? is because the inside of the stem looks carbon not alloy .
Headset - FSA ZS3
Grips - ESI
Saddle - Selle unsure of model NOW Ergon SMR3S Marathon saddle
Seatpost - On Off components NOW 3T Pro zero offset
Front brake - Avid XO
Rear brake - Avid XO
Cranks - FSA K Force Light carbon 170 with Blackspire Mono Veloce NW 30 tooth ring
Chainguide - NIL
Chain - KMC
Pedals - Crank Bros
Front derailleur - NIL
Rear derailleur - XT shadow plus 11 speed medium cage
Front shifter - NIL
Rear shifter - XT 11 speed
Cassette - SLX CSM7000 11 speed 11 - 42
Front hub - Stans 3.30 TI 15 mm axle
Rear hub - Stans 3.30 TI 12 x 142 axle
Front rim - STANS XC LTD 24 Spoke
Rear rim - STANS XC LTD 28 Spoke
Spokes - Sapim Race Black 2.0/1.8/2.0mm
Nipples - Sapim Double Square Secure Lock, Silver
Tyres - Rubena Charybdis 29 x 2.0 Now nobby nic addix of some sort 2.2 and 2.35
Tubes - Rubena sealant
Total weight - 12 Kg with pedals
Headset - FSA ZS3
Grips - ESI
Chainguide - NIL
Chain - KMC
Pedals - Crank Bros
Front shifter - NIL
