Without knowing what your skills are I'm still going to say that making a frame is out of your league. While the welding and profile cutting the tubes is difficult enough, you still have to work out your geometry and materials. Technology studies certainly used to need you to demonstrate a level of planning and knowledge. Without some real mathematical engineering (not possible with high school maths) you will end up with a lot of guess work and hunches. So it may be best to avoid a project where you will struggle to justify why you used a 1.5mm wall thickness tube instead of a stronger and safer 2mm. Also consider what if you build a DJ frame and it breaks on you, even professionally built frames fail so do you have faith in your skills and knowledge to use it after all the effort to make it?
Unless Technology Studies has changed since I did it, you get about the same amount of your marks from the design folio as you do the actual construction of the project. I didn't even finish my project and scored awesome marks so my tip is to concentrate on a component where you can really get into the technical design without having to go nuts with engineering justification. A hub or a stem would be better but there's similar problems here and then its a machining exercise. Are you going to be able to monopolise a lathe and mill for the time taken to make it? Are you going to use it? If you make a mistake will you have to start the whole project again or can you do it in small bits and assemble it? Good blocks of billet for machining might be hard to get at school, RHS and tubing will be cheap and easy.
Build something that you will use and its easier to stay motivated, perhaps something like a bike stand, or a rack with a locking/clamping mechanism that can't be defeated with bolt cutters. Do a big design feature like a rotating head that uses a spring/ball bearing detent with a spring loaded pin lock. Then you can get into the design and pro's/con's argument without having to download the One Steel catalogue. You'll get the added benefit of being able to use it for years at home and be able to modify it if your needs change.
Good luck with what ever you choose.
