cammas
Seamstress
His other “grass” plants in the backyard were definitely shoulder heightRookie! Ive grown my grass up to my shoulders before.
Feels like I went to bed Friday night and woke up Monday morning.
You didn't take Ambien or something? Any random new bikes or Franco Cozzo style baroque lounge suites in the house that weren't there last week? Join a new club that you do not talk about?Feels like I went to bed Friday night and woke up Monday morning.
My car had the recall software update done yesterday. I tried the so called "Intelligent Speed Limiter" on the way home. It is an improvement, but still a big fail as far as I am concerned.To make it worse, our new Subaru Forester has auto high low beam as well as active matrix headlights. The high low beam lever always returns to the middle. You push it forward to enable high beam and pull it back for low beam, but it does not stay in that position, it will return to center. Pulling it back also puts the lights on high beam while you hold it there. This means if the lights get automatically dipped for an oncoming car, and then you pull the lever back to set low beam, you actually flash high beam at the oncoming car. This has to one of the most stupid features I have come across in a car.
Another completely stupid feature in this car that is potentially deadly is the Intelligent Adaptive Cruise Control. This adjusts the vehicle speed to the speed signs. The first problem is that it does not start to slow the car down until you have passed the speed sign, and it also ignores advisory speed signs. I turned the feature off after it gave me two scares. The first one occurred when I had a truck tailgating me and I went past a 80 ahead sign. The car interpreted this as a 80 sign and hit the brakes with the truck on my tail. The second time occurred driving on the highway and the car saw a 80 sign on a side road and hit the brakes. How are stupid things like this allowed to be put on cars in Australia? Last week I received a recall notice for the car. The recall is to modify the Intelligent Adaptive Cruise Control so that it needs the driver to manually accept the speed change. I am not in a hurry for this update, as I will most likely leave this feature turned off.
I would just turn that function off.My car had the recall software update done yesterday. I tried the so called "Intelligent Speed Limiter" on the way home. It is an improvement, but still a big fail as far as I am concerned.
The vehicle speed no longer changes automatically, the detected speed change has to be acknowledged by the driver before the set speed changes.
According to the manual: 'When a speed limit sign is detected the border around the traffic sign indicator and the set vehicle speed blink for approximately 10 seconds. While these indicators are blinking, press the RES/SET switch to the "RES/+" side or the "SET/-" side to set the detected speed limit as the set vehicle speed.' ... 'The set vehicle speed does not change unless the RES/SET switch is pressed to the "RES/+" side or the "SET/-" side.'
Sounds good on paper, apart from pressing the RES/SET to the increase speed or decrease speed direction acknowledges the speed change, regardless of the speed change actually being an increase or decrease in speed.
The speed detection is based on the cameras and also a ISA map database. Unfortunately the cameras miss a significant number of the speed signs and the ISA map database is not up to date.
Driving home yesterday in an 80 zone, I went past a 60 school zone sign, I ignored this as it was outside school hours. At the end of the school zone the speed limit changed to 100, the car beeped as I went past the sign (I thought it beeped to say it saw the 100 sign, but I did not check the dash), I pressed the RES/+ switch and the car hit the brakes to slow down to 60. I don't know why it did this, as it was more than 10 seconds since the start of the 60 school zone. If it has missed the 100 sign, the worst it should have done is increase the set speed by 5kmh to 85, rather than changing the set speed to 60.
At another location as I went past an 80 ahead sign, the car detected this as an 80 sign, I did not acknowledge this as I wanted to slow down gradually. When I got to the actual 80 sign the card did not give me another chance to acknowledge the speed change.
I like the "Manual Speed Limiter". I tend to set it the dominant highway speed and leave it there. Slow down zones I adjust my speed as you would in any car. The unpredictable nature of the "RES/+","SET/-" paddle while in the "Intelligent Speed Limiter" mode (unless you are staring at the dashboard instead of the road) is a no go for me.
I also wish they would not use words like "Intelligent" to describe the ability of the car to detect speed signs. If it was actually intelligent, it would not detect 80 ahead signs as 80 signs, it would not pick up 60 signs on a side street and it would not miss so many signs completely.
I had turned it off not long after we bought the car. I turned it back on again to see if it was usable after the update. And the conclusion was it is getting turned back off again.I would just turn that function off.
At least you can turn it off. There are some annoying functions on some new cars that come back on as soon as you restart the car.I had turned it off not long after we bought the car. I turned it back on again to see if it was usable after the update. And the conclusion was it is getting turned back off again.
Like my partner telling me how to drive....At least you can turn it off. There are some annoying functions on some new cars that come back on as soon as you restart the car.
Yeah, you can't turn that off. The panic brake function that thinks you aren't going to stop is the worst one.Like my partner telling me how to drive....
It's the contradictions that get me...Yeah, you can't turn that off. The panic brake function that thinks you aren't going to stop is the worst one.
That's why consistency is important. Always drive it like you stole it.It's the contradictions that get me...
Rolling up to a t-intersection "GO! Ugh, you are just dawdling and missed the gap."
Then when I drive it like I stole it, I get "stop driving like a crazy person"![]()
You need a new Hilux. I'm actually genuinely impressed at how accurate the driver aids are, like the speed sign recognition, and how unobtrusive they are. To the point I don't turn them off. Lane keeping isn't perfect, but definitely user friendly, and can be disarmed so it will only stop you crossing the lines. You can turn it off completely, but to have to do that every time.My car had the recall software update done yesterday. I tried the so called "Intelligent Speed Limiter" on the way home. It is an improvement, but still a big fail as far as I am concerned.
When I can get a base model dual cab chassis 4x4 version for substantially less than seventy grand on the road...then I actually might.You need a new Hilux.
Still reckon a Shark would be the go for youWhen I can get a base model dual cab chassis 4x4 version for substantially less than seventy grand on the road...then I actually might.
Probably. But I've decided not to bother replacing the Transporter unless there's a catastrophic failure of a major oily part. New cars (even Toyota's) just simply aren't worth the money for the hassle based on the recent experiences of friends out this way.Still reckon a Shark would be the go for you
Sort of related but also conflicted. I fucking hate people who can't accept who they are.LTIH my wife complaining about not having connections with people, especially when I hear this...
Wife "It seems that family, and that family have been hanging out together recently, she told me"
Me "Who's she?"
Wife "That lady. What's her name?"
Me " I don't know who were talking to..."
I mean you can't complain about not connecting with people when you don't even know the name of the person you're talking to, it's not rude to politely say "I'm sorry I can't recall what your name is".
. You need a new Hilux. I'm actually genuinely impressed at how accurate the driver aids are, like the speed sign recognition, and how unobtrusive they are. To the point I don't turn them off. Lane keeping isn't perfect, but definitely user friendly, and can be disarmed so it will only stop you crossing the lines. You can turn it off completely, but to have to do that every time.
Only downside is the fucking ugly front end, but it's got a bull bar and I'll cover the rest with lights.
