IPF valve to Fox rear shock
shmity
On a similar note has anyone done this to a Float X? The IFP is situated in a piggy back and the bleed port that is near the eyelet like the standard CTD shocks is for vacuum bleeding the shock. So the IFP valve is a no brainer, but do i really need to vacuum bleed the fucker? This is the last shock in my stable shackled to shop servicing and Id love to do it myself...
redbruce
Yep. Need to remove the dissolved gas from the oil.
Link1896's youtube vid shows the issue (and solution).
https://www.youtube.com/watch?v=qdKyhVrU2fc
link1896
Is not a gynaecologist but will look at your fork
If you want to vacuum bleed, I'll make you the fitting
shmity
Thats oil aeration which affects all shock rebuilds and isn't done while the fluid is in the shock. Vacuum bleeding is to ensure there isn't any trapped air in the shock...
THanks mate, let me have a think if thats a(nother) rabbit hole I want to dive into at the moment... I certainly dont have any of the other required equipment to do it and its probably not an investment im interested in making at this point.
link1896
Vacuum bleeding does both, removes dissolved gases and trapped air in the damper.
Even when I'm SUPER gentle sucking oil in from the bottle into my chamber, there is a significant amount of gasses dissolved in the oil, as seen in that video clip.
link1896
Totally understandable.
link1896
Yeah right. Weird. I think I might have got the brass one for the alloy price
Ordered and paid for an $18 alloy fitting pn 22-600-04 and got a brass fitting in a 22-600-04 bag.
Someone let the new guy put stickers on bags.
nimbleviper
Cannon Fodder
possible part on forum rotorburn has M8 X 1mm pitch
Motorcraft® - Fuel Injection Fuel Rail Pressure Relief Valve
Replaces Original (OE) Part #:
EOAY9H321A, EA0E-9H321-AB
Part Number:CM3461
The external thread size of a Schrader valve is 0.305 inches outer diameter by 32 threads per inch
Exploded rp23 diagram shows part number 010-00-010 pellet retainer has 5/16" - 24tpi 0.220 TLG threading
Selling sites of CM3461 in UK:
can import from US:
Looked for other 5/16-24 to schrader valves on the internet but no orderable parts available.
nimbleviper
Cannon Fodder
FOX Pellet Retainer Set Screw 010-00-010-A
Fox Nitrogen Fill Delrin Ball 0.1875" 010-01-003-A
Fox Air Valve Pellet 010-00-011-A
wornoutwords
i'm trying to do this to an old rp23 boostvalve shock
does anyone know where in adel i might grab this 1/8 27-1 npt shrader valve? or the type of shop that might stock it? going off google it looks like it has uses across multiple industries. I live nearish an industrial area (lonsdale) where one place would definitely have it! i just need to be able to find them lol
I've been to motorcycle parts shop but they just had the tyre valves, same with a mtb repair/service shop
Possibly an automotive air condition spares shop.
Isildur
The Real Pedant
Let me have a look in the shed. I think I've got one from the days when I was going to do this, but never got around to! If I do, I'll pop it in the post for you.
wornoutwords
thanks! yeah i'll grab one, pm me your bank info and i'll transfer some money for the postage
I tried an AC place but they only did the 1/4 size ones, but I stopped by a motorbike specialist race tuner on the way home (http://www.racebikeservices.com.au/). They were really helpful, he handed me a valve that's from motorcycle fox shocks. it looks pretty close but he said the rated pressure is for 175 but it should be ok to do 300. I'll give it a shot over the weekend and see how it holds
