Item: Ibis Ripley LS with Fox Float EVOL Factory, Cane Creek 40 Headset, seat post clamp, spare cable ports, rear axle, instruction booklet
Sizing: XL frame, but a smallish XL, particularly by modern standards. Geo is reasonably similar to current model Large Pivot Mach 4 SL or Yeti SB115 for example, so if you normally ride a Large or even medium this could well suit you depending on how much dropper you want. I'm 192cm and really enjoyed riding it so if you prefer a smaller more playful bike it can work for tall riders too.
Item Condition: Cosmetically, fair. Lots of little stone chips and minor scratches around the rear triangle in particular and the matte finish has been worn smooth in various places. The most obvious scratches on the top half of the bike pictured (very superficial, image makes them look like gouges but it's just paint off). Underside of downtube had frameskin on it and looks good.
Built up and from a couple of paces it still presents well enough.
Mechanically, very good. Bearings were replaced not long before I stopped riding it. Shock has a .8 spacer in it to suit 95kg rider.
Cane Creek 40 Headset is a bit grubby and needs a clean, but I'm including brand new bearings. Downtube protector has a chunk out of it, available as a spare part if it worries you.
Reason for selling: Now on 500mm reach bikes so this feels too small. I'd build it back up otherwise.
Price and price conditions: $950 collected, can discuss postage if required
Extra Info: 29er, Boost 148, threaded BB, suitable for 120-140mm tapered forks (you'll want 150-160mm of steerer minimum for an average stack stem)
Pictures:
Pictures:
