CRANK_kona
hi just wondering how do you reduce weight on a bmx bike the bike is a 06 mongoose expert here are the specs, ive allready taken off the front brake, this is urgent!!!!!!!:
coloreer Green
Frame: Full Cromo
Fork: Cromo Blades & Steerer
Crankset: 3pc Tubular Cromo, 175mm, 36T Alloy CNC chainring
Bottom Bracket: Sealed Bearing (Steel cup) 8 spline
Pedals: Mongoose "M Pedal" alloy
Freewheel: 13t Cassette, loose ball
Chain: KMC Z-510
Rims: SUN ZX25 Alloy 36H front, 48H rear 20 x 1.75
Tires: Odyssey Rototiller (F) 2.10 Odyssey EarthScience (R) 2.10
Front Hub: 36H Alloy, 14mm Cromo axle
Rear Hub: 48H Alloy, 14mm Cromo axle loose ball cassette
Spokes: ED Black Steel
Front Brake: N/A
Rear Brake: Tektro Alloy U-brake
Brake Levers: Tektro full Alloy Hinged (rear only)
Brake Rotor: SST Oryg 1-1/8"
Handlebar: Mongoose Cromo 2pc
Stem: Mongoose front load 50mm Ext.
Grips: Odyssey Dualie, double density
Headset: 1-1/8" Ahead, oversized "Hammer" cups
Saddle: Mongoose Team Jumper, stitched with enforced rails
Seat Post: 25.4 straight Alloy, with Micro Adjust
Seat Clamp: Alloy single bolt
Extras: 1 pair axle pegs, Bada-Bing brake enhancer
GEOMETRY
FRAME SIZE:
HEAD TUBE ANGLE:
SEAT ANGLE:
CHAINSTAY LENGTH:
20
74
71
14.7
FEATURES
100% CrMo Trail Frame & Fork
3pc Tubular CrMo 175mm Crankset; Sealed Bearing
CNC Alloy 36t Micro-drive Chainring, 13t Cog
Mongoose Alloy Hubs w/ 14mm CrMo Axles ? Rear Cassette; Sun ZX25 36H (F) / 48H (R) Rims
Odyssey Rototiller (F) & EarthScience (R) 2.1" Dirt Tires
Tektro Alloy U-Brake w/ Bada-Bing Brake Enhancer & Hinged Alloy Lever
coloreer Green
Frame: Full Cromo
Chain: KMC Z-510
Front Brake: N/A
GEOMETRY
FRAME SIZE:
HEAD TUBE ANGLE:
SEAT ANGLE:
CHAINSTAY LENGTH:
20
74
71
14.7
FEATURES
