Hacks
Who are you?
  • Total voters
    65
stirk
I had to hack up a tool to get my air piston shaft out of my metrics so I could reduce the travel down to 160mm. Made it out of a cone spanner I never use and two computer case screws.
Very nice hack! Do the screws have enough strength to get the job done?
This is not mine, can't claim any credit for it.
Saw this in Hungary a few years back.
Pretty sure the wheel generator is putting power in for the speakers? Of which there is a bar mounted and a top tube mounted.
Full stereo.
outtacontrol
Once again, can't claim this one but saw it on Book of Faces and thought I would give it a lash.
How many times have you been on a roadtrip or out at the trails and need to re seat a tubeless tyre? You can either play pump lotto and hope to get lucky or duck off and try to find a servo.
Someone recently marketed a pump with a secondary chamber that you pressurise and then throw a switch and bang, on goes the tyre with one big hit of air.
Well you can achieve the same thing with a 2l Coke bottle, 2 valves with cores removed and a little plastic tube with a tap inline. Have tried it and it works perfectly :)
Ivan
I wonder if a soda stream bottle might be safer, as they're fairly strong and have a nice wide lid for fitting the valves.
outtacontrol
Maybe? I put 60psi in there with no trouble. Old mate on FB was a DH WC rider and they were talking about 100psi. I wasn't that brave haha
I did this too, 60psi was as far as I was willing to go. And was pretty wary at that.
Worked fine, I need to put a larger diameter outlet hose on to get better flow rate. Still got the bead on sweet as.
stoo
That's an ace idea!
I've filled those bottles to over 100psi a gazillion times and have never had one go off when I didn't want it to.
At that pressure they make a bloody great kaboom when you hit them with the axe or chuck one in the camp fire though!
stirk
Won't a larger outlet hose downstream from the valve decrease the pressure which is exactly what you need in this application to quickly blow the tyre up?
A tap connection on the bottle lid with the same ID as the hose would be ideal.
Ivan
Flow rate would be more important than pressure. Just like with air tools.
stirk
I don't know much about air pressure and flow rate, obviously, but if you go from a small outlet valve to a lager diameter hose back to a small inlet valve would you not be in the same position as running the same ID hose as the valves end to end?
What's the optimum design for this application?
Ideate
Senior Member
I thought these new oneup guides looked cool so I made one.
Found some aluminium plate to cut up.
Fired up the 3D printer..
I just need to clean the rest of the bracket up (cut texta coloured sections off). Works good, just like any chain guide costing me nothing but a bit of time and electricity.
Ackland
chats d'élevage
Do you think you could 3D print one similar to this for direct mount FD mounts?
Ideate
Senior Member
Was thinking about ways to deter the theft of my newly made rack but couldn't find anything quickly so I made this.
It supposedly stops you from undoing one of the bolts that attaches the tongue to the towbar. It's not very robust but would annoy me if I was going in for a quick steel job and only had a shifter or a socket/wrench.
It requires a T25 key (same as rotor screw/bolt) which are pretty common among my toolbox but again, not on my mind if I'm going in for a theft.
Drilled the bolt head
Tapped a thread
Cut a 24mm socket in half
Drilled the socket wall
Fitted to the towbar
I know you must be able to get something better than this but couldn't find anything.
mitchy_
Llama calmer
Plenty of keyed hitch pins avaliable
For example.
yep, but by the looks of it his tongue is bolted to the bar, ie. not hayman reece style receiver.
i've got the keyed pin on mine, but if they are going to go to the effort of unbolting my tow bar, go for it. i dont leave my bike on my rack any where out of sight anyway.
