No it is a Kore chainring that was sold by Wiggle!!Is it an ebay one?
Yeah kinda half wide all the way!Wide wide chain ring.
Nice
With the one I have the only way to get the narrow half of the chain link on to a tooth is with a hammer, probably would hold it pretty well once it was on though!Apparently...."The new Stronghold narrow/wide chainring uses a patented hooked tooth design that grabs and holds the chain around the ring when riding without slowing down release at the appropriate point. This creates excellent chain retention and eliminates the need for a chain guide."
I'd be interested to see how it works
Have you tried sitting a chain on it? It does look a little messed upWith the one I have the only way to get the narrow half of the chain link on to a tooth is with a hammer, probably would hold it pretty well once it was on though!
Yes, you can't get a tooth through the narrow (half) links of the chain.Have you tried sitting a chain on it? It does look a little messed up
If that's the case I need to teleport to the FW thread. Will have another look when I get home, but I tried a number of different ways to get a chain on and couldn't...Looks like they’re trying to copy this...
https://praxiscycles.com/technology/wave-tech-1x-rings/
FWIW I have one and it’s been flawless in the brief time I’ve had it. Inner tooth to wider chain link. MRP I think is using the same design.
