You’ll see Although I plan to attempt to my own wheel build so was going to bribe you with beer and ask to borrow your truing stand when the time comes so might spill the beans then.A lot of parts getting gathered up
What frame you looking at ?
Certainly, you can borrow the lot. Stand, tension metre, dishing tool, nipple driver ect... no excuses thenYou’ll see Although I plan to attempt to my own wheel build so was going to bribe you with beer and ask to borrow your truing stand when the time comes so might spill the beans then.
Legend. Waiting on parts so might be a while and will be in contact. Coopers?Certainly, you can borrow the lot. Stand, tension metre, dishing tool, nipple driver ect... no excuses then
Not at all, just come grab the stuff.Legend. Waiting on parts so might be a while and will be in contact. Coopers?
Cheers. Need parts to arrive and to measure up and then lace etc and do some more reading or risk ending up in the farkwits thread.Not at all, just come grab the stuff.
Have you ridden a DHF or an Assguy? How does the Mazza compare as a front(assuming you have actually ridden the Mazza!)?Looking for -
2 x Vittoria Mazza TNT G2.0 29 x 2.4
1 x Martello or Agarro TNT G2.0 29 x 2.35
Bike-Inn had them in stock but the postage was stupid.
Bike24 might have them back in stock soon but this availability estimate can change fast.
Loads of them, ran Assegai's nearly 100% on my Santa Cruz, still got at least 1 new one here and several partly used.Have you ridden a DHF or an Assguy? How does the Mazza compare as a front(assuming you have actually ridden the Mazza!)?
I have replaced a load of our jockeys with AilExpress jockey wheels.Anyone got a line on some Shimano 12 speed jockey wheels in Aus?
Wouldnt know what to look at now as there is a shit load of new ones.
Only thing I can add is steer clear of the ceramic bearing jockey wheels and get the ones with the SS Bearings.
jockey-wheel - Buy jockey-wheel with free shipping on AliExpress
Quality jockey-wheel with free worldwide shipping on AliExpresswww.aliexpress.com
Just as an fyi, the skinny alu jockey wheels (at least the ones I tried) made shifting very sub-par due to the loose fit between chain/teeth combined with a shit (very sloppy) bearing. In the end I grabbed one of the NW versions to use as the upper jockey wheel and swapped the bearing with a quality 689-2RS, and it's been flawless with better than stock shifting.From memory they are 13t ?
A quick look, these might do.
$4 shipping for as many as you want.
2.91AU $ 48% OFF|Bike Bearing Jockey Wheel Rear Derailleur Pulleys | Bearing Jockey Wheel Pulley 10 - Bicycle Derailleur - Aliexpress
Smarter Shopping, Better Living! Aliexpress.comwww.aliexpress.com
I have not tried the ones I linked but the previous ones I have had with SS bearings have been tight as and the bearing spun beautifully. They are definitely an upgrade from stock jockeys.Just as an fyi, the skinny alu jockey wheels (at least the ones I tried) made shifting very sub-par due to the loose fit between chain/teeth combined with a shit (very sloppy) bearing. In the end I grabbed one of the NW versions to use as the upper jockey wheel and swapped the bearing with a quality 689-2RS, and it's been flawless with better than stock shifting.
Thanking you.XT 12spd long cage derailleurs back in at Pushys.
Shimano XT RD-M8100 12sp Long Cage Rear Derailleur Shadow+
Buy Shimano XT RD-M8100 12sp Long Cage Rear Derailleur Shadow+ Now at Pushys. Lowest Price, Secure Shopping and Fast Delivery from Australia's Best Online Bike Storewww.pushys.com.au
Me too, GX be gone. Pity the shifter was $85Thanking you.
Needed that
