ACT FOUND Left XT brake lever (M8000), or similar set
droenn
Fat Man's XC President
Item: Shimano XT M8000 lever - left side.
Price range/Willing to Pay: around $25
Extra Info:
The mounting clamp just snapped on my aged XT brake lever when trying to reposition and tighten. Checking if anyone has another laying around.
Alternatively, a matching set of left and right levers (I-spec II preferably) that are compatible with the older Shimano calipers (e.g. M675, M7000, M8000 etc) might be the go if cheap.
Reckon you could just replace the clamp? I have the carcass of a m9000 if it helps
Not sure - they seem like the lever body is largely a single unit, so not possible to just change out the clamp? It snapped at the red line here:
Suspect that the m9000 would be a bit different (and probably beyond me) to throw the m8000 guts into?
Not the cheapest or best option, but you might be able to salvage spares from your broken one?
I swapped over the M8100 lever from my (disassembled) Banshee and it works really well. I will swap the other one when I get some more olive/barbs so they match (the M8100 feels so much nicer).
Unless there is a cheap M8000 out there somewhere, I'll probably end up just get another set of M8100 levers and have them on both bikes.
If only they had both sides! MTBD have stock of both at least.
