You have the deepest inferiority complex of anyone on this website.The “look” of a light is irrelevant... What probably matters more is that you look like a try hard SUV driver tosser driving with your fog lights on.
Its just the globe I am replacing, so I'm not making changes to any "directionality".The colour makes no difference for a given amplitude (due to tinting yellow lamps would normally deliver less), but make sure you take care to orient them correctly as per the guidelines. They need to be aimed very low and short to avoid creating bad glare for the driver (and possibly other drives)
Must be a different part of sydney, up on the northern outskirts we get heavy fog a lot.I'm in Sydney so foggy weather is only an issue about 5days a year, so the preferred fog effects of yellow doesn't matter to me.
I was just amused he called WRX try hards and drives an Anorak with fogs on... Its ironicYou have the deepest inferiority complex of anyone on this website.
Oh we get fog, but as I say, not much of an issue very often. Baulkham Hills.Must be a different part of sydney, up on the northern outskirts we get heavy fog a lot.
It's a 4by, just drive over shit that gets in your way.Another issue here to consider, also related to being a considerate road user - led globes in reflectors designed for halogens just makes a bad glare situation for other drivers worse.
Please just leave them off. They hinder your own ability to see where you’re going and annoy everyone else.
You consider owning a French motor vehicle a viable option (Renault Clit). That does not lend your opinions too much credibility.I was just amused he called WRX try hards and drives an Anorak with fogs on... Its ironic![]()
Its fog lights. They do not hinder ANY driver vision.Another issue here to consider, also related to being a considerate road user - led globes in reflectors designed for halogens just makes a bad glare situation for other drivers worse.
Sure do:It's a 4by, just drive over shit that gets in your way.
PS: have you got your emissions cheats enabled?
Clit. Hilarious, I see what you did thereYou consider owning a French motor vehicle a viable option (Renault Clit). That does not lend your opinions too much credibility.
If they annoy others, stiff shit.
Foggies aren't directional, hence the glare regardless of the globe. The main lights have a hood inside the globe.The colour makes no difference for a given amplitude (due to tinting yellow lamps would normally deliver less), but make sure you take care to orient them correctly as per the guidelines. They need to be aimed very low and short to avoid creating bad glare for the driver (and possibly other drives)
I'm replacing a halogen globe with an LED one.Clit. Hilarious, I see what you did thereI bow to your superior manliness.
As for vision, you do know they a bright light right in front of you contracts your pupils and blinds you to the range of the low beam lights? It probably only a bit, but it sure doesn’t improve things!
By all means go nuts with the “it looks cool” theory for all sorts of stuff - but mucking safety critical stuff like lights is pretty silly.
Using your fog lights like that is ILLEGAL for a reason....
