Are these ALL threaded inserts?So I have been back and forth with Porter this week putting together the design. They are very efficient like Waltly, you send in your changes and they have them back within the day. I sent this one this morning and it came back this afternoon.
It's getting very close to finished. I have shortened the seat post to take a 170mm dropper and changes the braze ons for bottle mounts but the rest is quite similar to the current HT it just fixes a few little niggles I have with this one.
Happy for any thoughts or things to consider, and yes @Tubbsy it takes a lot of its geo from the Paradox
I'm going to use bolt on cable guides for all of the routing so the ones that are 64mm apart are for bottles and the others are for cable guides.Are these ALL threaded inserts?
Some look like sensible spots for bottle mounts and what-not but I'm scratching my head on some of the others...
Looks to me like a few of 'em should've been cable mounts and not threaded inserts.
Gotcha! Getting bolts into those top 2 nearest the head tube is gonna be tight!!!!I'm going to use bolt on cable guides for all of the routing so the ones that are 64mm apart are for bottles and the others are for cable guides.
I've checked the measurements a few times but I need to go back again and check now. There are a few available to 3d print which can be filed down to fit in tight spots.Gotcha! Getting bolts into those top 2 nearest the head tube is gonna be tight!!!!
Checked it again, in a bit of panic. Yeah there is a bit over 20mm between those 2 mounts which should be plenty of space.Gotcha! Getting bolts into those top 2 nearest the head tube is gonna be tight!!!!
Do you have CAD? Getting the first one in will be OK, what about getting the second one in. Won't the one you've just installed be in the way? How far do the mounts protrude and what head screws you using? If using M5 x 12 c'sunk head screws and the mounts are very low profile you might be OK.Checked it again, in a bit of panic. Yeah there is a bit over 20mm between those 2 mounts which should be plenty of space.
That is a question I've been meaning to ask, where does everyone get their cable guides from? @wkkie?
No these are all good questions. I had not thought about the process of actually getting them in, I had just measured that they would fit. I'm thinking now that the first one on the down tube might need to move about 10mm down to give enough clearance to install them both.Do you have CAD? Getting the first one in will be OK, what about getting the second one in. Won't the one you've just installed be in the way? How far do the mounts protrude and what head screws you using? If using M5 x 12 c'sunk head screws and the mounts are very low profile you might be OK.
Sorry for spinning you out if it's all good!
I'd add another insert between the upper two on top of the downtube. It's a rattle-prone area, especially going around the outside of a curve, just after a single clamp holding brake hoses/cables that are repeatedly being pushed/pulled every time you turn the bars. The clamps either need to truly clamp the cables/hose, or you'll likely get some slip and free play in the cables.So I have been back and forth with Porter this week putting together the design. They are very efficient like Waltly, you send in your changes and they have them back within the day. I sent this one this morning and it came back this afternoon.
Also remember if you're using socket head screws you need to be able to at least get the ball end of a hex key in there, or be prepared to cut one of your keys down.No these are all good questions. I had not thought about the process of actually getting them in, I had just measured that they would fit. I'm thinking now that the first one on the down tube might need to move about 10mm down to give enough clearance to install them both.
Honestly looking at the design I'm thinking internal routing for the dropper will be easier... I seem to remember someone saying that earlierI'd add another insert between the upper two on top of the downtube. It's a rattle-prone area, especially going around the outside of a curve, just after a single clamp holding brake hoses/cables that are repeatedly being pushed/pulled every time you turn the bars. The clamps either need to truly clamp the cables/hose, or you'll likely get some slip and free play in the cables.
Also if you are looking to keep the option of running the rear brake hose and shifter cables down the down tube, you might want to consider adding cable guides along the seat-stays. Although my comfort factor having additional welds mid seat-stay wouldn't be that high if I'm honest (thinking long term fatigue cycling here). It may also be worth considering using a straighter downtube (at the headtube end), to allow for a strengthening gusset under the down tube where it joins the headtube.
If you're getting really OCD, get the dropper-cable port rotated slightly off the centreline of the seat-tube, as the cable won't be running centrally down the downtube due to the offset of the clamps.
Yeah happy to cut one if need be but will try and design enough clearance not to need to.Also remember if you're using socket head screws you need to be able to at least get the ball end of a hex key in there, or be prepared to cut one of your keys down.
So are you thinking something like the BfeIt may also be worth considering using a straighter downtube (at the headtube end), to allow for a strengthening gusset under the down tube where it joins the headtube.
Yes.So are you thinking something like the Bfe
Or more like this?
I'm not familiar with the specifics of different gussets and their locations so would be interested in everyone's thoughts.
I ordered mine from CRC...Checked it again, in a bit of panic. Yeah there is a bit over 20mm between those 2 mounts which should be plenty of space.
You could always move them more to the outside of the frame if that suits your routing.No these are all good questions. I had not thought about the process of actually getting them in, I had just measured that they would fit. I'm thinking now that the first one on the down tube might need to move about 10mm down to give enough clearance to install them both.
It's a real can of worms. You want the gusset to add strength but it can actually create a stress riser or fulcrum if it's not done properly. Unless you can run some FEA you'll need to rely on what xcad have done in the past that works. No gussets might be fine too.So are you thinking something like the Bfe
Or more like this?
