First trail wheelset advice
I know, it's just a confidence thing.
Truing of wheels is easy, the simple act of tightening or loosen a spoke to pull the rim to the desired position.
Look at it like a boat in a canal, a rope going to each bank, holding it in the middle of the canal, if you need to move it closer to one side, give a bit of slack on one side and take that slack up with the other. There is no magic to it.
There is a little bit of tension difference on NDS vs DS but that wont matter much with a few half turn adjustments to true a wheel.
HamboCairns
Thanks for all the bananas
Good to know, I guess if I truly bugger it up there's always an LBS on hand!
PJO
in me vL comy
Also stick a little bit of tape near the end you are turning so you can see when the nipple actually turns on the thread rather than just the spoke twisting.
EDIT: should say on the spoke near the end you are turning.
I hate building wheels... its a chore to build my own but I do it so I know exactly how they were built, tensioned and any things that were not 100% pleasing eg... spokes could have been 1-2mm longer (3-4mm and I would order new ones)
I'll box up my wheel building gear and send it to you... every MTBer should know how to build his own wheels :p
I build a few….and enjoy it as long as I’m not in a rush. I’d hate to do it as a job and I’d never do for others.
‘Gear’? You mean a zip tie taped to frame or fork? Never owned a truing stand or a tension meter….and never had an issue with a wheel I’ve built in all my years…..but probably should make a placeholder post in the COTFW thread in readiness.
I've got the lot... its a shit job, need to make it as painless as possible.
Truing stand
Tension metre
Nipple driver
Nipple wrench
Nipple tray
Nipple assembly tool (best buy ever)
Various spoke keys
Bladed spoke holder
Dishing tool
Probably my most hated job is swapping over like for like rims after 2 blokes I know have dinged the crap out of them.
lightbrain about 4pm
Truing stand
Tension metre
Nipple driver
Nipple wrench
Nipple tray
Various spoke keys
Bladed spoke holder
Dishing tool
Some specific info about nipple wrenching please. Google has been very generous now I am overwhelmed.
Truing stand
Tension metre
Nipple driver
Nipple wrench
Nipple tray
Various spoke keys
Bladed spoke holder
Dishing tool
You Irish are a weird lot…and can say that being Irish.
Knuckles
Lives under a bridge
Truing stand/old fork
Tension metre/smart phone guitar tuner
Nipple driver-yes, for building, or youll go fucking insane, although I have seen a bloke bulid with a filed screwdriver tip in a drill
Nipple wrench-definatley
Nipple tray-whaaaa?
Nipple assembly tool (best buy ever)/cotton tip, with the cotton bud pulled off one end
Various spoke keys-the only requirement
Bladed spoke holder/pliers, vicegrips, bbq tongs
Dishing tool/couple of old wooden coathanger, a ziptie and some screws.
There is a tonne of hacks for building tools, investment just depends on how often ewe'll do it.
Knuckles
When I started mine were all home made, just bought the bits over several years.
I bought a Park spoke tension metre, only because it was stupidly cheap, I mean I'll grab 7 dozen, cheap.
The tone metre worked fine, and I don't think I've used the tension metre more than once. As long as the tension is even, and it's not floppy or rim crackingly tight, I really don't think it's super critical for a mong builder, who is going to be riding the wheels themselves...like a mong.
I googled the nip tray, pretty ingenious, I usually just line them up manually on a bit of grey tape.
#freebritney
johnny
I'll tells ya!
Agreed. Just get dt swiss double butted comp spokes and brass nipples. Done
Edited due to auto correct preferring double butter to anything that’s been double butted
Forgive my ignorance, I've never organised for a wheel build before.
So the spoke calculator says for the Hope hubs and DT rims, I need these spokes for the front wheel:
Left spoke length: 290.6
Right spoke length: 291.4
But the DT Champ spokes come at lengths of 290 & 292
377364
I assume that the 290 & 292 lengths are the right ones for me. Is that right?
johnny
I'll tells ya!
Can't find a spoke calculator that has EX511 29 either. This is getting frustrating, everything in life should be simple and set up ready for my specific level of (mis)understanding.
yuley95
Yeah, I think that would be safe. Some people say to always round up but I think going up from 290.6 to 292 is pushing it. I’ve come very close to running out of thread by rounding up before.
Short answer - yes, go 290 and 292
EDIT: looks like you have linked to spokes that are 1.8 - 1.6mm thick @johnny . I would go 2mm - 1.8mm with appropriate nipples (2mm). You often get nipples and washers with dt rims. They are ok but they are alloy. You are better off buying some brass nipples while you are getting spokes. people will have opinions on this but I’ve build a number of wheels with dt pro lock brass nipples 14mm long and they’ve been great. Hope that helps
johnny
I'll tells ya!
Thanks, haven’t purchased anything yet as I can’t determine which length I need for the rear wheel.
