That’s true... The rubber band sort from bunnings. You’re right, there are probably better ones!what kind of strap wrench, there are a few kinds!
ive so far resisted anything that might leave a mark, soft taps didn’t do anything...Soft hammer and tap around the colar, the light shocks help loosen seized threads.
ive been tempted...Search - Our range
www.bunnings.com.au
That's one to put in the book.First check you are turning it the right way is it the male or female part you are turning ?
Then either use rubber then rachet strap or some tape or rubber and put on a hose clamp as tight as possible then use a shifter pushing against the hose clamp worm drive.
#notatradieFirst check you are turning it the right way is it the male or female part you are turning ?
That's what I've done before but with an old rubber tube, got to be really careful you don't bite into the collar with the grips through the rubber.Wrap the strap wrench rubber around the collar and use the vice grips. My bunnings one was shit the rubber pulled out of the handle trying to undo a dropper collar...
tried that...Wrap the strap wrench rubber around the collar and use the vice grips. My bunnings one was shit the rubber pulled out of the handle trying to undo a dropper collar...
Just to be clear of the issue, is the seatpost stuck in the seat tube? As that appears to be what you are implying.X Fusion Manic, stupid tight... Anyone got any magic tricks before I break out the vice grips and leave gouge marks in it....? Can not get this bloody thing off. Bought a strap wrench even. Its on super tight.
I'm thinking maybe putting it in the freezer...
