Sell that gas powered heap off and get a real shock.
Sorry, no real suggestion. I've seen too many dhx's with stuck down sindrome.
Have you spoke to TF Tuned (I assume it was them) yet?
Meaning the reliability of their seals is terrible.He said it's leaking air... what's that got to do with a stuck-down??
Firstly I'd suggest talking to Dirtworks to see if they're going to warrant any other Push Tuning work, if not, which is what I'd suspect, i'd take it to your LBS and have them either service your shock or send it to Netti to get the work done.C'mon here people let's be nice to the Fox shock, it goes well even with no air in it.
It leaked before I sent it to get pushed (with TF Tuned), then was fine for about 2 months, then leaky leaky again.
TF Tuned said to send it back for another service.... Which is exactly what I expected them to say, but frankly, ~$400 for another leaky shock ain't worth it.
So I was wondering what other suggestions people had?
Jesus $400 dollars for a service?!C'mon here people let's be nice to the Fox shock, it goes well even with no air in it.
like i said we know its leaking because the air pressure drops over time, i have the same shock as mike and mines starting to develop an air loss problem too, we pump it up to just over 100psi and after a few rides mikes is down at 0psi and mines at about 90psi, ive used many shock pumps on mine and it gets the same reading, and it cant be mikes shock pump because hes added 100psi about 5 or so times now and the shock probably wont work too well on 500psiYeah nice one dilzy, I'm pretty sure mike- is talking about a coil shock too. FYI, I've been running DHX-Air's with great success in DH bikes for the last two years, the stuck down issues were corrected from 07 onwards with new seals. The main cause is lack of lubrication in the air chamber, which 95% of owners pay no attention to. For giggles, I've seen more blown coil shocks over the time I've run these.
Anyway my first question to mike- would be, how do you know it's leaking? A loss of pressure when attaching the pump is perfectly normal, as the pump needs to fill; and the amount will vary from pump to pump. Like Tech-DW says, the air can only go two ways - and in many years of running DHX's (coil and air) I've never seen those two seal sets go bad (the IFP o-rings and valve + reservoir endcap o-rings).
I'd make sure it's actually leaking before doing anything, and then replace (one at a time, in this order) the schrader valve core, the valve's external o-ring, the reservoir endcap's o-rings, and if all that fails... look at the IFP. As suggested already, changing the IFP o-rings will require a shock rebleed.
I'd say yours is only losing about 10psi from when you connect the pump to the shock the pressure due to is released into the hose/pump over a greater area, hence the lower pressure reading.like i said we know its leaking because the air pressure drops over time, i have the same shock as mike and mines starting to develop an air loss problem too, we pump it up to just over 100psi and after a few rides mikes is down at 0psi and mines at about 90psi, ive used many shock pumps on mine and it gets the same reading, and it cant be mikes shock pump because hes added 100psi about 5 or so times now and the shock probably wont work too well on 500psi
Yes, DHX5 coil.Anyway my first question to mike- would be, how do you know it's leaking? A loss of pressure when attaching the pump is perfectly normal, as the pump needs to fill; and the amount will vary from pump to pump. Like Tech-DW says, the air can only go two ways - and in many years of running DHX's (coil and air) I've never seen those two seal sets go bad (the IFP o-rings and valve + reservoir endcap o-rings).
I'm confused...Second question, to be honest, I can't say 100% it's leaking, but I know air don't just grow legs and walk away.
