Goudgey
Hi Team,
I've installed a new M6100 Deore crankset and bottom bracket to a frame with 73mm BSA bottom bracket shell and am concerned that the non-drive side crank arm is not installed correctly because the small black retaining clip is sitting proud of the end of the crank arm. I believe this clip is meant to sit flush with the end of the crank arm.
Is the clip meant to protrude slightly and have I installed the clip correctly
I've installed the BB including 2.5mm spacer on drive side in accordance with Shimano's directions. I also believe I've installed the crank correctly, with play being taken out using the plastic end bolt and the crank bolts being torqued to spec.
Any advice/guidance is gratefully received.
Cheers!
Cheers!
