Oracle
Howdy farkin home/professional mechanics,
Noticed the other day that my chain line is not pefectly parallel to my frame so pulled my LX hollowtech II BB/crankset apart late last night to see whether I could simply swap the plastic spacers around and inspect/regrease threads whilst I was at it. I've a 68mm BB and currently have 2 spacers on Right (drive/chainwheel) side and 1 spacer on the Left (crankarm only) side and am using the hollow plastic tube in the BB.
The Chain Line as seen over-looking the bike in relation to the top tube (with chain on middle chainring and 5th rear cog) diverges quite obviously from the 5th rear cog to the middle chainrings of the bike, by ~1cm as an estimate from the two ends of the chain. This translates to the chain line being near parrallel whilst using 44 chain ring and 11 tooth rear cog, and very out of line when using 22 chain ring and 30 tooth rear cog.
Looking at the BB cups last night I realised the Left and Right cups were not identical length with the Right (chain rings side) being longer, to account for two spacers as compared with the Left (crank arm only side) with one spacer. Consequently I didn't swap the spacers over as the left side cup would not thread as deep into the BB (68mm) as the right side cup would if I swapped the plastic spacers. The casette is about as close to the frame as I would like it so can't really move it more than a few mm's.
So my question is can/should I:
(1) reverse the cups keeping the 3 plastic spacers and BB adapter (the hollow plastic tube), or
(2) remove the plastic adapter/tube and one or both spacers on the Right (drive) side cup, or
(3) just leave everthing as it is and not worry about running a non-parrallel chain line?
(4) anything/something I might have missed?
Cheers and thanks in advance!
