I’ll get a proper PYR up soon. Will get some more photos tonight though.
A few things I overlooked on this one so build will change a bit.
Frame didn’t come with seatpost clamp but I managed to find one at LBS.
Need shock hardware for front mount (I’ve made my own till proper hardware arrives this week.
Front wheel I was originally going to run has torque caps (swapped wheel with paradox as that’s running a pike at the moment).
Front brake is running a 3mm rotor aswell (Normally they sell set with 3mm rotor and spacer for rear line only)
Cranks will probably change (these are 170s), I normally run 165s now and have some 160s to try but they were bought for the Madonna when it arrives
Fork will go on the Madonna if I like it (I can’t not try it though) this will get either a fox 38 or a bomber that I was originally going to use
