Coffee Drinkers Anonymous
no sieve yet, but an idea...
spreading ground coffee on a tissue by finger captures the fines in the tissues roughness, and the "coarse" particles just roll across.
(trying to salt Bae on a white plate didn't work because the superfines clump together)
Comparison below are both #6 grind setting,
- upper one with about 10g beans dumped in, and capturing mid-late grinds. There's a wider range of particle sizes, with lots of very fine particles captured on the tissue (and can feel the superfines between fingers)
- lower one is single fed beans. Much fewer fines, and the more consistent larger particles just rumble across, leaving far fewer fine bits behind.
arguably somewhere between the two is a good balance of varied particle sizes for different extraction, without too many fines to clog the puck.,.. vs unimodal size with less variation in extraction
Speechless. Fucking speechless.
That's a really good blend to work on getting your workflow down pat.
I think a team of dedicated grain sizes each restricted to a single size checking every particle for grind consistency and then a mixer (with backup) to ensure the perfect blend of sizes.
Something like this could work.
