Coffee Drinkers Anonymous
Measuring does help. It is one of the easiest things you can do to ensure consistency, yet commercially so many places cant be bothered.
Measure the grams of ground coffee going into the basket, the time extraction takes (lots of variables to consider here), and the amount of espresso produced. For home use it doesn't need to be too complicated, especially as you are unlikely to be running too many coffees at once or wanting to waste off an imperfect or trial shot.
I jumped on the grill briefly yesterday.
Latter art is something I have always struggled with on home espresso machines. No explanation why.
Pressure gauge should stay fairly constant when pouring your shots. It is mostly abput knowing the machine has enough bars to force extraction at a high enough pressure. Commercial is usually around 9 or 10 bar, my home machine has 15! Youll get a more noticable drop in pressure from dumping heaps of water out (like filling a few tea pots) or blasting a heap of milk.
Best to adjust home grinders gently while they are grinding. You dont want to ping something by trying to crush a bean stuck in there...
This all seems too complicated. I change the grind settings depending on beans but not much as our 3 standards are similar. Fill the porta filter level. Compress to a uniform height and then extract for a set time. All determined y weights, weight of ground beans, time for a set weight of shot to extract...
Explain to me again about sheep bladders...
And I reckon that's too complicated! Grind until the pile seems the right height, squash the pile to what seems to be the right height (at least so it fits in the machine), insert filter into machine, place mug under filter, turn the dial to make hot water flow for its preset time or volume or whatever, add milk (straight from the fridge) to the mug, put mug in the microwave for 1 minute on high, coffee is ready!!
Squish is / was very variable so I buyed one of those adjustable depth squishers. Do all the complicated shit once, set the gear up then imbibe. The beaker I extract into has a setting for one, one point five and two shots depending on the basket being used.
Grind will change according to environmental conditions (humidity, wind, temperature, etc). It will be your most frequently varied control.
How is your:
- dose?
- tamp pressure (what's ypur puck like?)
- fill level inside basket?
- extracted volume?
- flow rate?
I could have just whined "why is my noob coffee both sour and bitter and sometimes fast and sometimes slow"
besides, while my bits heal up, I need distractions ;)
Always start with the coffee beans. Either something you know well, a high quality commercial bean like Allpress or Campos or a neutral single origin like Columbian.
Next is the grinder. Have you zeroed it correctly. Have you run in the burrs with enough crappy beans or rice.
What kind of hopper/auger does it use. How do you get the fines out from the last grind.
What kind of basket are you using. Is it a precision straight wall or a high extraction tapered wall. The tapered wall will need a coarser grind, but also be more forgiving.
Next is the grind itself. Have you got accurate scales and timer. Did you use a WDT then a leveler. Have you got a clicky tamper or can you judge the tamp by feel.
What kind of time are you getting for a 2:1 extraction ratio. Adjust the grind finer for a longer more acidic profile. Go coarser for a low contact sweeter profile.
Are you getting a muddy wet puck or a solid puck that breaks cleanly when you bang it out.
There is no right answer but if you can get consistent with things like tamp pressure, weight of beans, and pour time for 2:1, it allows you to figure out what needs to change to get the best out of your beans and equipment.
Once I had the Mazzer I found my inconsistencies were mostly tamping so I buyed this. Took a few goes to dial in but it works.
Holy cow you guys are super nerds. I do really really enjoy a good coffee but if I had to do any more than press two buttons and froth the milk on my Breville barista pro in the mornings while my eyes are still glued shut with sleep I dunno what I’d do.
It’s taken a little dialling in goes a bit spaz if I chuck random beans in the hopper but it’s consistently pretty damn good.
