fjohn860
Alice in diaperland
Frame: Carbonda FM1003 (now CFM-1266)
Rear shock: 205x65 Marzocchi Bomber CR/SR Suntour TriAir2 205x65
Fork: Marzocchi Z1 Air
Handlebars: PNW Range Alloy 50mm rise, 10° backsweep
Stem: Funn Funnduro 60mm
Headset: Carbonda generic
Grips: OneUp Thick
Saddle: WTB Volt
Seatpost: KS Exaform 900i 190mm
Front brake: Zrams (Zrace lever on DB8 caliper, soon to be MT5 Caliper)
Rear brake: Zrams (Zrace lever on BD8 caliper, soon to be MT5 Caliper)
Cranks: Senicx 165mm
Chainguide: N/A
Chain: Sram PC-1110
Pedals: SRUDEC TNT (AliEx T-macs) 10mm pins
Front derailleur: N/A
Rear derailleur: Shimano Deore 5100
Front shifter: N/A
Rear shifter: Shimano Deore 11sp
Cassette: Sunshine 11-51T 11sp
Front hub: Hope Pro 4
Rear hub: Hope Pro 4
Front rim: Nextie NXT29XM36
Rear rim: Nextie NXT29XM36
Spokes: Sapim
Nipples: Two
Tyres: WTB Judge 29x2.4 Front, WTB Trail Boss 29x2.4 Rear
Tubes: In the frame
Total weight: 15.5kg
This addition to my fleet came about due to @beeb the enabler.
I wasn't on the look out for a new bike, but beeb mentioned he had this frame sitting in his house not being used and thought maybe I'd want a longer travel bike for shuttles etc.
I told him I have nothing to build it up with, but he wasn't taking that as a no.
It took some time, but I was able to sneak some purchases (forks, rear shock, wheels etc) and get this thing rolling.
First ride out, one thing I noticed was the chainstay length (445mm) and how it made cornering a cinch. You can be feeling tired or lazy and it just tracks through corners so well. I was comparing this to the 430mm stays on my 2018 Smuggler which requires an aggressive over the front body position otherwise the front washes more easily.
Initially I had a Bomber CR but I felt that it gets deep into the travel without much effort even though I'm running the correct spring rate. I was wondering if a larger volume air shock might be the ticket, so purchased a SR Suntour TriAir.
Only one shuttle day on the air shock setup, but initial thoughts are that it is definitely better with the air shock. Currently have 2 volume bands in the negative chamber, but I'll definitely be tinkering with it over the next few rides.
Overall it's a great bike, last couple of shuttle days I've had a few people ask about it as it obviously looks the business, but doesn't really look like anything from the big brands currently.
Grips: OneUp Thick
Saddle: WTB Volt
Chainguide: N/A
Chain: Sram PC-1110
Front shifter: N/A
Spokes: Sapim
Nipples: Two
Tubes: In the frame
