I pulled the DH bike out of the shed to find that the rear tyre was flat (it's running tubeless). I pumped it up but could feel air leaking from around the join in the rim.
Holding the rim up to the light, you can just see a pinprick hole in the side of the rim. Don't know what make the rim is - it was put on by a local wheelbuilder, who assured me it was bulletproof! Admittedly that was about 4 years ago.
Is the rim likely to be falling apart? A bit of araldite to fill the hole and go tubeless again? Or just run a tube? Or throw it away and start again?
The dent in the rim doesn't leak - only the pinprick hole.
