Buying A New Frame / Complete Bike Megathread, CHECK IT BEFORE POSTING
philfbm
ADMIN EDIT - For information on quality complete bikes, go check out this thread. For information on frames only, read on.
Ok so here the go with this. So many people are posting threads about what frame they should buy, so i have created this thread to make less repeating threads all asking the same question. Everything is categorised in brand names so Enjoy.
FBM BIKE CO: www.fbmbmx.com
FBM Autopilot frame:
Mike Tag Signature Frame
Toptube 19-7/8", 20-1/8", 20-3/8", 20-5/8" or 20-7/8"
Weight=2.4kg, BB height=11 5/8"
HT=75deg, ST=71deg
CS=13-1/4" to 14-1/4"
Seatstay Brakemounts,
Mid BB
$799.95
FBM Deployer Frame:
Derek Girard Signature Model
TT Length : 20 1/4", 20 3/4", 21" or 21 1/4"
Rear End Length 14" (center to center)
Mid Bottom Bracket/Integrated Headtube
BB Height 11.75
HT Angle 74.5 degrees/ST Angle 71 degrees
Weight 5lbs 3oz
NIL-8 Heat Treated
$799.95
FBM Pw Moto Frame:
Phil Wasson Signature Frame
TT Length 20.75"
Rear End Length 13-3/4" to 14-3/4", BB Height 11.5"
HT Angle 74.5 deg, ST Angle 71 deg
Weight 5.4 pounds
Integrated Headtube/Mid Bottom Bracket/Seatstay Brakemounts
$549.99
FBM Stairmaster Frame:
Aaron Ross Signature Frame
Toptube Sizes 20.5, 20.75 or 21/Read End Length 13-5/8" - 14-3/8"
Externally Machined Integrated Headtube/Mid BB
Headtube Angle 74.5/Seattube Angle 71/Butted Seatube
BB Height 11.5"
Weight - 5 lbs 3.6 ozs (20.75tt)
3/16" Thick Heat treated 14mm Dropouts
Made in the USA with 4130 Chromoly tubing
$799.95
FIT BIKE CO: www.fitbikeco.com
Hawk Frame
Chase Hawk Signature Frame
- 100% Sanko Butted and Heat Treated Tubing
- Integrated Headtube/Integrated Seatclamp/Mid BB
- Steep 75° Headtube Angle/High Tech SOAREX Bridges
- Graphics by Chase and Adam Roye
- Weighs Only 5 pounds!
$529.99
Sreies 3 Aitken Frame
New Hi-Tech Lightweight Aitken Signature Frame
- TT 20", 20.5", 20.75", 21"
- CS 13.75", BB 11.8"
- HA 75 deg, SA 71 deg
- Mid BB
- Integrated Headtube/Removable Gyro Tabs
- Seatstay Brakemounts
- Weight 4lbs 7oz !!!!!
$749.99
Sreies 3 Homan Frame
Van Homan Signature Series 3 Frame
- Built Tougher Than S3 Aitkens To Take Serious Abuse
- TT/CS: 20.5"/13.75", 20.75"/13.75", 21"/14.25"
- HA 74.5 deg, SA 71 deg, BB 11.9"
- Integrated Headtube/Removable Gyro Tabs/Mid BB/Seatstay Brakemounts
- Weight 5.2lbs
$749.99
FLY BIKES: www.flybikes.com
3 Amigos Frame
SIZES AVAILABLE :- 20.6TT/13.75CS, 21TT/13.75CS, 21TT/14.25CS
INTEGRATED SEATCLAMP/INTEGRATED DOWNTUBE GUSSET
INTEGRATED CHAIN TENSIONER INSIDE DROPOUT - 1 INCLUDED
SPANISH BB/INTEGRATED HEADTUBE/REMOVABLE GUIRI GYRO TABS
CHAINSTAY BRAKEMOUNTS COMPATIBLE WITH 25/9 GEARING
WEIGHT - 2.450 grs. (5.39 pounds)
$579.99
Diablo 3 Farme
Redesigned by Brandon Pundai.
Spanish BB
Integrated Headtube & Downtube Gusset
Machined Dropouts
Removable Guiri Gyro Tabs & Chain Tensioners
$649.99
Mosca 2 Frame
Eduardo Terreros Signature frame.
19.8, 20.2 or 20.6 toptube
Integrated Headtube/Removable Guiri Gyro Tabs/Chainstay Brakemounts/Spanish BB
Integrated Downtube Gusset/Machined Smaller Size Dropouts/Internal Chain Tensioners/Slimmer Tube Diameter
Weight 5.2lbs
$649.99
Pantera 2 Fame
Sergio Layos Signature Frame - New Revised Version
20.6 or 21 toptube
Spanish BB/Integrated Headtube/Integrated Downtube Gusset
Chainstay Brakemounts/Removable Guiri Gyro Tabs/Integrated Seatclamp
Internally Machined Dropouts/Removable Chain Tensioners
New Smaller Diameter Tubing, Enlarged Vent Holes & Lower Standover Height
$649.99
MACNEIL BIKE CO www.macneilbmx.com
Bibi Frame
Bibi Signature Frame- Lifetime Warranty
· Top tube - 20.75” top tube, 13.5” chainstay
· Head tube 74.5°, seat tube 71°
· Seat stay brake mounts
· Removable Gyro tabs/Spanish BB/Integrated Headset
· Double-butted seat tube and down tube
· Drilled out Seat tube for weight saving
· Weight: 4.84lbs
$649.99
METAL BIKE CO www.metalbikesbmx.com
Rebel Contender Frame
· Toptube: 20.75”, 21", & 21.125"
· HT 74.5 deg, SA 71 deg, BB 11.8"
· Mid BB, Internal headset, Lightning bolts lazer cutouts in dropouts
· Drawn tubing to make it lighter in some areas and thicker in areas that need more strength
· Built in seat clamp (T-bolts, so you don't have to worry about stripping threads)
· Weight: 4 lbs 13 oz. w/ seatclamp and hardware!!
· Black or Mint Green
$749.99
MUTINY BIKES www.mutinybikes.com
Burlish Frame
New Trails Frame from Gaz & Joe with a dose of design input from the legendary Sponge!
TT Length 20.25" or 21" Sanko Tubing (Mixture of Double Butted & Straight Gauge Tubing)
HT Angle 74.5 deg, Integrated Headtube, Removable Gyro Tabs, Mid BB, Revised Cable Guides
Plate Bridges on Chain & Seatstays with Mutiny Badge cutouts
Tattoo Graphics!
Weight 4.8 lbs
$649.99
Nocturnal Frame
Brandon Hoerres Signature Frame
100% 4130 Sanko Chromoly, Double Butted Top & Downtube
Special Teardrop Shaped Downtube to Prevent Denting.
Top Tube: 20.75", 21"/Chain stay: 13.75" slammed/BB Height: 11.5"
Head Tube: 75 degree/Seat Tube: 69 degree
Mid BB/Integrated Headtube/Seatstay Brakemounts/Removable Gyro Tabs/Revised Cable Guides
Heat Treated 5mm Dropouts/Heat Treated Chain & Seatstay Plates
Weight: 5.3 lbs
$649.99
Sinister Frame
2007 Joe Simon Signature Frame. As ridden by Jamie Bestwick!
TT Length 20.6" or 21"
Sanko Tubing, HT Angle 74.5 deg
Weight 5.2 pounds
Integrated Headtube, Removable Gyro Tabs, Revised Cable Guides, Mid Bottom Bracket
Seatstay Brakemounts or Brakeless Version available
$649.99
Mutiny X Shadow Conspiracy Frame Kit
LIMITED EDITION MUTINY X SHADOW CONSPIRACY FRAME, FORK, HEADSET & STEM KIT.
Very Collectible & Very Very Dope.
Consists of:
- Mutiny Sinister Frame - Gloss Black-Matt Grey Finish with Etched Graphics
- Shadow Conspiracy Creeper 026 Forks - Gloss Black Finish with Etched Graphics
- Shadow Conspiracy Attack Stem - Limited Matt Grey/Silver Finish
- Triple 6 Sealed Integrated Headset
Paint & Graphics direction by Shadow Conspiracy. 100% Chromoly by Mutiny.
Check www.Defgrip.net for the full lowdown!
$849.99
REDLINE BIKE CO www.redlinebikes.com
Device Frame
2007 DEVICE FRAME
+ Designed & ridden by Rooftop, Dustin Guenther & Tyrone Williams
+ 100% Japanese Sanko Chromoly Tubing
+ Integrated Headset
+ Mid BB Shell
+ Heat Treated Head Tube, BB Shell and Dropouts
+ 20.5” and 21” top tube lengths available
+ Removable Detangler tabs
+ WEIGHT: Under 6 lbs.
$459.99
S&M BIKE CO www.sandmbikes.com
Black Bike V2 Frame
For People who don't want an LAF because they a) Need a stronger frame or b) Don't like 75 degree headtubes.
Top Tube Lengths: 20.5", 21.0", 21.25"
Chainstay Range: 13.75" - 14.75"
Head Angle: 74.5 degrees, Seat Angle: 71.0 degrees
Weight: 5lb 4oz
Removable Gyro Tabs, Engraved S&M Headtube Logo
Integrated Headtube
Mid BB
$749.99
L.A.F Frame
Light As F*&k Frame
- Made in the USA from Super Therm, air hardened, chromoly tubing.
- 75 degree HT -FAST STEERING!
- Integrated headtube with lower gusset
- Engraved S&M logo on HT
- Mid BB
- Chain or seatstay U-brake mounts
- Weight 5 lbs.
$749.99
Stricker frame
Josh Stricker Signature Frame
- Toptube 20.5", 20.75" or 21.0"/Chainstay Range: 14.0" - 15.0"
- Head Angle: 74.5 deg/Seat Angle: 71 deg
- Integrated Headtube shaped to look like a Regular Headtube with Cups
- Mid BB/BB Height: 11.8"
- Integrated Seatclamp/Seatstay Brake Mounts
- Anchor Shaped Seatstay Brace for Maximum Pirate Steez
- Supertherm Tubing with Toptube & Downtube Gussets
- Weight: 5 Pounds
$749.99
SUNDAY BIKE CO www.sundaybikes.com
2007 wave Frame
Toptube 20", 20.5" or 21"
Rearend 13.75"
Weight 5.3lbs
8mm HOLLOW Dropouts
Rustproofed Inside & Out
New Externally Fluted Dent Resistant Downtube
$649.99
TERRIBLE 1 BIKE CO www.terribleone.com
Garret Byrnes Frame
Garrett Byrnes SFA (Sweet F*&k All) Signature Frame.
- 20, 20.5 or 21.25 Toptube
- Integrated Headtube drilled for Fly Guiri Gyro Tabs
- Spanish BB/Chainstay Brakemounts
- 74.5 deg HT, 71 deg ST
- Chainstay Grindplates/3/16 Heat Treated Dropouts
- Weight 5lbs, 7 ounces
$699.99
Ruben Alcantra Frame
Ruben Alcantara Signature Frame.
- 20.3 or 20.8 Toptube
- Spanish BB
- 74 deg HT for a more stable ride
- Chainstay Brakemounts
- Weight 5lbs, 10 ounces
$699.99
THE TAKE BIKE CO www.thetakeonlife.com
Ivy Frame
New from the FBM Frame Shop.....Super light simple design.
TT: 20.5", 20.75", 21"
Rear End Length: 14" (center to center), BB 11.5"
HA 74.5 deg
Mid BB/integrated Headtube
Weight: 5 pounds
Made in the USA
$799.99
One True Ave
Colors: Mint-Ting-a-Ling, Clear Metallic
Sizes: 19.25 ", 19.75", 20.25"
Bottom Bracket: Mid
Head Tube: Integrated
Weight: 5.5 pounds
Made in the USA
$749.99
Take Time Frame
-INFO TO COME-
UNITED BIKE CO www.unitedbikeco.com
Squad Frame
- Toptube/Chainstay - 19"/13.75", 20.6"/13.75", 20.75"/14.25", 21"/14.25" or 21.25"/14.5"
- HT 74.5°(75° on 19" & 20.6")/ST 71°
- 4130 Japanese Sanko Chromoly
- Integrated Headtube/Removable Tabs/Chainstay Brake Mounts/Mid BB
- Double Butted Seattube
- Weight 5.3lb
$649.99
Trinity Frame
Corey Martinez Signature Frame
- Toptube/Chainstay - 20"/13.75", 20.5"/14" or 20.85"/14"
- HT 74.75°/ST 71°
- Weight 5.4lb
- New Caleb Kilby Edition edition features Tan colourway & Caleb design Stickers
$649.99
WETHEPEOPLE BIKE CO www.wethepeople.de
Beyond Frame
Bargain Price Frame from Colognes Finest!
- 100% Chromoly Construction
- 20.5" Toptube/13.8" Chainstay
- 74.5 Degree Headtube/71 Degree Seat tube
- Integrated Headtube/Mid BB
- Drilled for Removable Gyro Tabs
- Weight 2.84kg
$399.99
Millar Lite V2 Frame
Millar Lite V2 (Clint Millar Pro Signature)
- TT: 20.7“ or 21“, CS: 13.75“ to 14“
- 4130 Chromoly Sanko Japanese Tubing with Unique wethepeople 'offset' double butting
- HT: 74.5°, ST: 71°
- Heat Treated Mid BB
- Heat Treated Integrated Headtube with Removable Gyro Tabs Included
- Lasercut 5mm Thick, Heat-Treated, 4130 cr-mo, 14mm Dropouts
- Thinner Diameter Tubing than 2006 Version.
$649.99
Ovoid Frame
- TT: 20.25" , 20.65" or 21", CS: 13.8“
- Ovalised Sanko Japanese Chromoly Tubing
- HT: 74.5°, ST: 71.5°
- Heat Treated Mid BB: Height: 11.8“
- Available With or Without Chainstay Brakemounts
- Strong Street & Park Frame, Higher BB and Overall Stance than other WTP Frames.
$649.99
Phoenix Frame
Hi-tech evolution of the 4 Seasons frame
- TT 21"
- CS 13.75“ to 14“
- HT: 74.5°, ST: 71° BB 11.5“
- Mid BB/Integrated Headtube
- Weight: 2.441kg (5.37lbs, 86.1oz)
$649.99
EASTERN BIKES www.easternbikes.com
Grim Reaper
Lightest frame available!
Toptube 20.5 or 21"
Integrated Headtube, Spanish BB & Removable gyro tabs
Integrated Seatclamp & slotted tubing
Now with Integrated Downtube Gusset (Internally Butted)
HT=74.5deg, ST=71deg
Weight=1.971kg.
$649.99
Reaper Frame
# Double-butted down tube and seat tube
# Removable gyro tabs
# Small gussets at the seat tube
# Droputs: 5mm thick, hardened chromoly, very compact
# Bottom Bracket: Hardened chromoly, Euro BB or Press Fit
# Head Tube: Hardened chromoly, internal(Campy style)
# Rear Triangle: 14" center to center and 13.6" slammed at the front of the drop out
# 5.3 lbs
# Available Top Tube lenghts: 20.25, 20.5, 20.75, 21
# Colors: Black, Pearl Orange, Teal or Navy
$TBA
Dragon Frame
* 100% Quality 4130 Chromoly
* Internal Headset
* Now with removable gyro tabs
* CNC machined Headtube w/ Extra Large Vent Holes
* Euro BB
* 20.5" Toptube
* 14.25" Chainstay
* Laser cut Dropouts
* Weight = 6.1 lbs
* Colors: Black, Silver, Tan
$TBA
Np II Frame
* Double-butted down tube and seat tube
* Removable gyro tabs
* Intergrated Headset included
* Droputs: compact 5mm thick, hardened chromoly
* Bottom Bracket: Hardened chromoly, uses Press-fit
* Head Tube: Hardened chromoly, internal(Campy style)
* Rearend: 14" center of dropout
* Available Top Tube lenghts: 20.5 or 21
* Colors: Black or Honey Mustard
* Weight" 5.40 LBS
$TBA
Titanium Grim Reaper
MOST EXPENSIVE FRAME EVER
* Full 6Al-4V Titanium
* Compact 6mm thick
* Spanish bottom bracket
* Internal Headtube
* Rearend 13.63
* Headtube angle: 74.5 degrees
* Seattube angle: 71 degrees
* Colors: Ti
* Weight" 2 LBS 6 ounces
$1199 AMERICAN
So there you go, if you have any other questions or if i have missed a frame you are interested in just post a reply.
Cheers Phil
bowzaa
Fuck you must have been bored phil although i think you copied it from somewhere:p
Nice work though, but some of the retail prices are a bit out there.
Will try and see you at greensy tomorrow.
x
Good effort, will be really helpful to a lot of people.. Sticky?
To be honest though there are more people asking about what complete bike to buy.
/\/\3qq3/\/\
Nice work mate.
Must of had some time on your hands.
Like Josh said about the completes if you put them in then has potential for a sticky.
DH_co
Thats sweet.
I have no knowledge of pounds and stuff....
How many ounces to a pound? And what is 1 ounce= gram? 1pound=kilogram?
(google is being ghey)
but sick thread, sticky....
x
^ Nah, it already has a lot of potential for a sticky! I meant that there are probably more people out there though making threads about 'what complete bike should I buy?'.
But yeah Meppem good idea, if he has extra time on his hands then he could do some of the complete bikes too, if not I can do it.
DH_co, there are 16 ounces in a pound, and about 2.2 pounds in a kilo. E.g. my bike is 11.2 kg, which is 24.7 pounds.
/\/\3qq3/\/\
Though the Grim Reaper Ti weights as much as a feather I've got the normal Grim Reaper and I was stoked about the weight and believe it was worth the money.
Ryan
Radministrator
Fricken nice work there fmbphil, stickified with reference to that kick arse thread on pinkbike added.
x
Phil, do you want to do the completes or should I?
Edit: don't worry, saw the link.
barcelona
i don't know where you got those price lists from but the fly bikes 3 amigos is $579 from cycology in glaidsville.
jesse
freewheel
Squid
bmx chains
pintle chains
can any of u guys tell me who other than KMC make a pintle chain for bmx.
and also whats the best method for tapping new bearings into a frame
T1/Petei
Squid
hey,
is the grim reaper v2 very good cause some of my friends said it was good but i have heard they brake easily :confused:
kiwi_86
Squid
seshin
HT=75deg, ST=71deg
Mid BB
$799.95
FBM Deployer Frame:
BB Height 11.75
Weight 5lbs 3oz
NIL-8 Heat Treated
$799.95
FBM Pw Moto Frame:
TT Length 20.75"
Weight 5.4 pounds
$549.99
BB Height 11.5"
$799.95
Hawk Frame
$529.99
- Mid BB
$749.99
- Weight 5.2lbs
$749.99
3 Amigos Frame
$579.99
Diablo 3 Farme
Spanish BB
Machined Dropouts
$649.99
Mosca 2 Frame
Weight 5.2lbs
$649.99
Pantera 2 Fame
20.6 or 21 toptube
$649.99
Bibi Frame
· Weight: 4.84lbs
$649.99
$749.99
Burlish Frame
Tattoo Graphics!
Weight 4.8 lbs
$649.99
Nocturnal Frame
Weight: 5.3 lbs
$649.99
Sinister Frame
Weight 5.2 pounds
$649.99
Consists of:
$849.99
Device Frame
2007 DEVICE FRAME
+ Mid BB Shell
$459.99
Black Bike V2 Frame
Weight: 5lb 4oz
Integrated Headtube
Mid BB
$749.99
L.A.F Frame
Light As F*&k Frame
- Mid BB
- Weight 5 lbs.
$749.99
Stricker frame
- Weight: 5 Pounds
$749.99
2007 wave Frame
Rearend 13.75"
Weight 5.3lbs
8mm HOLLOW Dropouts
$649.99
Garret Byrnes Frame
$699.99
- Spanish BB
$699.99
Ivy Frame
HA 74.5 deg
Weight: 5 pounds
Made in the USA
$799.99
One True Ave
Bottom Bracket: Mid
Weight: 5.5 pounds
Made in the USA
$749.99
Take Time Frame
-INFO TO COME-
Squad Frame
- Weight 5.3lb
$649.99
Trinity Frame
- HT 74.75°/ST 71°
- Weight 5.4lb
$649.99
Beyond Frame
- Weight 2.84kg
$399.99
$649.99
Ovoid Frame
$649.99
Phoenix Frame
- TT 21"
- CS 13.75“ to 14“
$649.99
Grim Reaper
Toptube 20.5 or 21"
Weight=1.971kg.
$649.99
Reaper Frame
# 5.3 lbs
$TBA
Dragon Frame
* Internal Headset
* Euro BB
* 20.5" Toptube
* 14.25" Chainstay
* Weight = 6.1 lbs
$TBA
Np II Frame
* Weight" 5.40 LBS
$TBA
* Compact 6mm thick
* Internal Headtube
* Rearend 13.63
* Colors: Ti
$1199 AMERICAN
Cheers Phil
HEy mate Dave here thought might be a good idea to add a seshin shithawk V2 to your list as its a mad frame at a sweet price $559
Top Tube Length 20.5 - 20.75 - 21
Rear End Length 13.5 - 13.75 inch (On 20.5 and 20.75 models)
13.75 - 14 inch (On 21 inch model)
BB Height 11.8
HT Angle 75 degrees
Headtube Integrated
ST Angle 71 degrees
Bottom Bracket Mid (Press Fit)
Seat Tube 25.4mm
Dropouts 5mm Thick. Laser cut 14mm axle slot
Weight 5.2 lbs - 5.4 lbs depending on TT length
Colors Jet Black
Warranty One full year against cracking, and LIFE TIME on manufacturers defects!
TUBE SPECS
All tubing is Aircraft Grade 4130 Chromoly
TT 1.37" O.D. .035 wall thickness
DT 1.5" O.D. .049 wall thickness
SS 7/8" O.D. .035 wall thickness
CS 7/8" O.D. .049 wall thickness
EXTRA
All tubing, head tube, bottom bracket and dropout's are heat treated.
Cable guide near the headtube for easy cable routing.
Comes with removable gyro tabs, cable routing and brake mounts!
